Author Topic: plenum pipes  (Read 1444 times)
marrus69
  • bracknell
    • 52 mv6 3.2
plenum pipes
« on: 25 December 2011, 17:07:59 »
the pipes that exit the rear of the plenum,where do thay go,when i removed plenum the other day thay had all gunk in them,just wondered if i could force water down them,or do i have to remove them. :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: plenum pipes
« Reply #1 on: 25 December 2011, 18:14:00 »
a lot of users tend to use carb cleaner for breathers not water hth :y
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: plenum pipes
« Reply #2 on: 25 December 2011, 18:15:57 »
Remove matey! It's breather system, these pipes go to crank case vent house, strictly prohibited to fill up with water!  ;)
C20NE - X25XE
Re: plenum pipes
« Reply #3 on: 25 December 2011, 20:50:56 »
Yep - remove them and clean them out with carb/ injector cleaner. Also remove and clean the black plastic breather body on top of the plenum as it gets blocked too. ;)
As said,if you force water down the breather pipes you will end up with a mixture of oil and water in the sump. :o
marrus69
  • bracknell
    • 52 mv6 3.2
Re: plenum pipes
« Reply #4 on: 26 December 2011, 00:20:23 »
ok thanks did the black plastic bit, got most of gunk out of those pipes but thier must be more further down,gives me somthing to do with my 2 weeks of.
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: plenum pipes
« Reply #5 on: 26 December 2011, 23:09:29 »
Take a look in the Maintenance Guides Index on here - there is a V6 Cleaning Crankcase Breather System guide that I found useful.   :y
I feel like a military academy. Bits of me keep passing out.
