Author Topic: passenger window...  (Read 4737 times)
hotel21
  • The Kingdom of Fife
Re: passenger window...
« Reply #15 on: 29 December 2011, 15:59:45 »
Very slow going up/down when door open or when door closed?
Could be door/window guide is twisted a tad and eases when door is open allowing slow movement but extra tensions when door closed causes winder mechanism/guides to cause a jam.
What are the door gaps like?  Even all the way round and passenger side the same as the drivers side?
Possibly a repaired/replacement door after some damage....
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #16 on: 29 December 2011, 16:04:11 »
all door gaps are the same passenger side.. front and rear look the same, very slow when the door is open... it only moves about an inch when closed???
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 29 December 2011, 16:07:32 »
is there any danger of premeture activation of the airbags ??? and thanks for your input :y
Really immature but that made me giggle  ;D ;D ;D
RIP Paul Lovejoy
hotel21
« Reply #18 on: 29 December 2011, 17:36:43 »
Try when door closed to put a bit of pressure from inside to out on the window frame - not the glass itself - and see if that makes any difference.  If its easier them the door glass needs to be dropped and the frame pulled out a tad at the top to square up the glass guides....   ;)
