Author Topic: passenger window...  (Read 4726 times)
mav1508
  • surrey
    • 2.6 MV6 saloon
passenger window...
« on: 27 December 2011, 18:37:22 »
evening all, yet another problem with my 2.5 v6.. that i have only had for 4hrs.. >:( this one relates to the passenger electric window.. it will operate via the drivers console but only when the doors open.. ??? the passenger switch not at all. i was thinking the wiring was getting trapped in the door hence only working when the doors open?? any ideas??
Re: passenger window...
« Reply #1 on: 27 December 2011, 18:59:40 »
All fuses OK? No idea of fuse numbers, but there's two feeds for the windows.
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #2 on: 27 December 2011, 19:02:22 »
sounds like a broken wire or dirty connection in door connector plug to me, open door and move wires about whilst using switch to see if dies again
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
« Reply #3 on: 27 December 2011, 19:03:21 »
Fuse #`s 1 & 15
« Reply #4 on: 27 December 2011, 19:04:38 »
Passenger window is opening when driver's door is open  ;) ;)
« Reply #5 on: 27 December 2011, 19:05:36 »
Fuse #`s 1 & 15
I knew someone Rob would know  ;) ;) ;)
adey2
« Reply #6 on: 27 December 2011, 19:07:07 »
meant try from passenger side, was too busy feeding dogs buiscuits
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #7 on: 28 December 2011, 16:57:04 »
evening all,
checked all the fuses... all ok checked the door connecter all seems intact.. but now i have airbag/seat belt warning light on the dash. this only appeared after i removed the door connecter ???. this is strange.. because the passenger window will open from the drivers side controler but only if the passenger door is open..weird, not a very safe way of opening the window :D  i have ordered a new passenger switch and pray it works :)
hotel21
  • The Kingdom of Fife
« Reply #8 on: 28 December 2011, 17:02:11 »
Looks like your car has side airbags. (just checked, its a W plate so will have) You either had the ignition switched on when disconnecting or switched it on whilst disconnected, hence the airbag fault showing.
The door has impact sensors within detecting sudden compression of the panel which activates the side airbags on the seats.
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #9 on: 28 December 2011, 17:14:45 »
that will be about right.. the key was in the ignition  :-[.., is there any way of clearing the warning light.. ???
hotel21
« Reply #10 on: 28 December 2011, 17:17:40 »
Either by proper tech2 or a device with appropriate software on it.  No doubt someone will be nearto your location and will shout out.   :y
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #11 on: 28 December 2011, 17:29:42 »
is there any danger of premeture activation of the airbags ??? and thanks for your input :y
hotel21
« Reply #12 on: 28 December 2011, 18:02:51 »
Its my understanding that if the airbag light is illuminated then the airbags default to safe - i.e. will not deploy in the event of an accident - so worth getting the light reset.   :y
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #13 on: 28 December 2011, 18:14:14 »
thanks very much :y
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #14 on: 29 December 2011, 15:54:33 »
re-update, none working passenger window.. finally had time to take the passenger window switch off... i suppose it helps to have the thing plugged in..and the new switch arrived today, but in still refuses to work with the passenger door closed?? open its fine.. it feels as though its sticking, very slow at going up or down..?? im not sure were to go now?? any ideas anyone????????
