Author Topic: also got noisy tappets on startup  (Read 1552 times)
mav1508
  • surrey
    • 2.6 MV6 saloon
« on: 28 December 2011, 16:43:02 »
evening all, i have the same problem on start up.... until the engine gets up to temp, once its warmed up its fine.. chrisgixer. which wynns should i try for my omega 2.5 v6 petrol ??
cheers  :)
« Last Edit: 28 December 2011, 18:08:02 by hotel21 »
hotel21
  • The Kingdom of Fife
Re: also got noisy tappets on startup?
« Reply #1 on: 28 December 2011, 17:08:20 »
SteveAvfc.
    • Mv6 2.6 V6
« Reply #2 on: 28 December 2011, 17:17:21 »
Try Wynns lifter treatment along with an oil change should do the trick. If not could be a cracked manifold or worse stud gone on manifold. Tried all this on mine when i had the same problems turned out to be the stud but i decided to put up with it.
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #3 on: 28 December 2011, 17:25:05 »
thanks for that,
i will pop down to halfords and get some..hopfully that will cure it.. :) i wouldnt mind ive only had the car less than one day.. :(
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #4 on: 28 December 2011, 17:30:55 »
thanks for that,
check there is no saw dust in engine......
Solar charger fitted.
If not Broke dont fix it..
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #5 on: 28 December 2011, 17:57:41 »
im not sure what mean.. ???  :) no really it drives ok once its warmed up :)
hotel21
« Reply #6 on: 28 December 2011, 17:58:05 »
thanks for that,
Forever helpfull Rusty, as per usual......   ::)
Where does the quantum leap from noisy lifters to a sump full of sawdust come from?  And how does that lift the hopes of the original poster?
sheeeeezzz....     :-X
hotel21
« Reply #7 on: 28 December 2011, 18:00:10 »
You have checked the oil level since getting the car?  Apart from being black/dirty, no 'sawdust' in there?   :y
Get some lifter treatment, read the instructions on the bottle and use accordingly and drain/change oil as recomended thereafter.   :y
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #8 on: 28 December 2011, 18:03:31 »
know saw dust... oil level seems fine :) i didnt even start this post, but it discribes my cars symptoms exactly.. will try wynns tomorrow.. thanks :y
hotel21
« Reply #9 on: 28 December 2011, 18:05:37 »
Yup, I realised that already.  Will split so its a stand alone thread.   :y
« Last Edit: 28 December 2011, 18:08:11 by hotel21 »
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #10 on: 28 December 2011, 18:13:18 »
cheers, home now... :y
