Author Topic: Cost of replacing glow plugs from a garage 2.5TD  (Read 5878 times)
SR-71Blackbird
  • Watford
    • 2.5TD Silver Auto Elite
« on: 30 December 2011, 11:33:43 »
Hi guys,
Any ideas what the cost of changing all 6 glow plugs would be (including or excluding the plugs) from a garage. I know I could possibly change them myself but it seems like the intake manifold needs to be removed etc and I don't feel like doing that so only comments about garages/pros doing it please.
Has anyone had this done recently and how much did it cost to have all the plugs changed and did you let them buy the plugs or did you bring your own?
Thanks
Re: Cost of replacing glow plugs from a garage 2.5TD
« Reply #1 on: 30 December 2011, 11:37:14 »
Last ones I did was about £45 for plugs (NGK) and completed within my lunch hour, including stopping to make the tea :)
Most backstreet garages are around £50 an hour outside London....
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 30 December 2011, 11:51:52 »
What? Did that include inlet fanimold off? With it off I took at least two hours. :(
« Reply #3 on: 30 December 2011, 12:07:35 »
Depends how much practice you've had taking tractors apart and putting them back together (in the rain), I guess. :-X
Shackeng
  • Ramsbury
« Reply #4 on: 30 December 2011, 12:21:51 »
Well I've only changed them once, about 6 years ago, in 12 years/110,000m so I certainly would not claim any expertise, but I am surprised if you can change them without removing the manifold. ???
Edit: and it was in the garage not the rain!
« Last Edit: 30 December 2011, 12:23:50 by Shackeng »
hoofing it
« Reply #5 on: 30 December 2011, 12:39:11 »
Manifold off(try not to drop the nuts above the starter lol) you will need to buy manifold gaskets X-6 they cost about £6-8 quid each.
Easy job to take on should take around an hour :y
« Reply #6 on: 30 December 2011, 13:37:02 »
Manifold off - that takes most of the time, changing the plugs themselves is about 5-10 mins.
« Reply #7 on: 30 December 2011, 13:37:44 »
I seem to recall you enjoyed it so much, that you rolled around in the puddles for hours? :P
maracus
  • Cambs
  • Hahaha cool- 1000+bhp combined on the drive!!!!!!!
    • 3.0mv6 auto, cav4x4 turbo
« Reply #8 on: 31 December 2011, 13:11:41 »
I'm sure I changed mine without moving the manifold... Wobblers and knuckle pieces saw me good iirc... Had to modify a socket with a angle grinder as I was being too tight to buy an injector socket...
The weather is here... Wish you were beautiful!
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #9 on: 31 December 2011, 14:19:20 »
  did mine a few weeks ago. plugs cost me £37 20p (bosch from a local motor factor) & gaskets were from a range rover outlet which at the time were on offer at a quid apiece. job took me two hours  :y will buy a socket for the job before i attempt it again though had all sizes but that one. :y
davie b
  • greetland halifax
« Reply #10 on: 14 January 2012, 10:07:27 »
I did mine middle of last year after been quoted £120 for 3 hrs labour by a local independant did it myself I removed inlet manifold just have to be careful of the nuts on inside of manifold I filled socket with grease and this held onto nuts also be careful not to trap wire on injecter no4 :y :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #11 on: 14 January 2012, 22:11:46 »
:o  That's £36 to £48 for the six.
Top tip: Wherever it was, never get them from there again ! :y
I payed about £8.00 for all six. Admitedly this was almost two years ago, but I doubt the price will have increased that much since then.
If you don't have a local motor factors with reasonable prices then Fleabay has these at £17.11 inc. P&P here:
http://www.ebay.co.uk/itm/INLET-INTAKE-MANIFOLD-GASKET-VAUXHALL-OMEGA-2-5-1994-1996-/230717437512?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b7d4b648
« Last Edit: 14 January 2012, 22:19:01 by Turk »
