Author Topic: display  (Read 5209 times)
GLENNY BOY
  • dartford
    • cd 2.6 auto v6 2002
Re: display
« Reply #15 on: 01 January 2012, 20:50:42 »
but bulbs havent gone so why is display telling me to BRAKE CHECK its telling me incorrect infomation thats what im saying but why would it tell you wrong info
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: display
« Reply #16 on: 01 January 2012, 20:53:28 »
They've aged and now they offer less resistance than when they were new. Replace with a pair of decent branded ones and the message will go away, it's a false error.
Re: display
« Reply #17 on: 01 January 2012, 20:57:21 »
Just do as you're told & put a couple of new bulbs in!!  ;) ;) ;) ;) ;) :y It'll cost you a couple of quid.  :y
GLENNY BOY
  • dartford
Re: display
« Reply #18 on: 01 January 2012, 21:02:24 »
ok ok ok thanks :y :y :y :y
Re: display
« Reply #19 on: 01 January 2012, 21:04:50 »
;D ;D ;D
;D ;D ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: display
« Reply #20 on: 01 January 2012, 21:07:29 »
;D ;D ;D
;D ;D ;D
Don't worry Glenny Boy. I'm too inquisitive for my own good most of the time. Coupled with myself being a bit mechanically retarded doesn't help  ;D ;D ;D ;D ;D ;D ;D
RIP Paul Lovejoy
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: display
« Reply #21 on: 01 January 2012, 23:19:00 »
Glenny Boy if it is any consolation I went through exactly same situation - neighbour checked lights and all fine but fault light came on. At the finish I just put new bulbs in and no probs thereafter.
hotel21
  • The Kingdom of Fife
Re: display
« Reply #22 on: 01 January 2012, 23:33:31 »
Its a resistance thing.
You should know that, James Bond wise, resistance is futile.....   ;D
Re: display
« Reply #23 on: 02 January 2012, 00:46:45 »
Re: display
« Reply #24 on: 02 January 2012, 11:34:15 »
Lets clarify (For post 1998 cars).
Switch on (without foot on brake), you should get:
CHECK BRAKELIGHT
Foot on brake, this should extinguish, if it doesn't, its likely a failed brake switch.
If you get:
BRAKE LIGHT
thats the check control unhappy with the bulb conditions, so check bulb, holder, brightness, and if necessary, replace bulbs for quality items.
Re: display
« Reply #25 on: 02 January 2012, 11:35:07 »
Pre 98 similar, but no CHECK BREAKLIGHT, just illuminates the CHECK icon until brake pressed.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: display
« Reply #26 on: 02 January 2012, 13:19:01 »
I had a similar problem after pulling one of the bulbs to measure the quiescent current (prompted by another thread on here) a week ago.
Next time I drove off, the BRAKE LIGHT warning came on and I stopped the car.  It is a doddle to drop the rear seat and pull the light sub-assembly out and you can press the pedal and see the lamp at the same time.  What a design!!!!
Re-seating the bulb was all that was required in my case.  Mighty odd as the connections are as clean as can be (visually).
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
