Author Topic: display  (Read 5193 times)
GLENNY BOY
  • dartford
    • cd 2.6 auto v6 2002
display
« on: 01 January 2012, 15:54:02 »
hi all happy new year my display keeps saying brake light but brake lights are fine any ideas  :y :y
Re: display
« Reply #1 on: 01 January 2012, 16:02:15 »
Ensure a decent connection in the bulb holder & use a quality brand. Cheap lamps can & do cause a problem for the lamp check   electrickery.  ;)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: display
« Reply #2 on: 01 January 2012, 16:51:14 »
If its when you first turn the ignition on that's normal. It does all the checks then you press the brake pedal, it goes off and that's it.
TC and BnQ Trade holder.
GLENNY BOY
  • dartford
Re: display
« Reply #3 on: 01 January 2012, 18:53:11 »
oh yes its says breaklight check when started but on display after check it comes up on display brake light but all brake lights are working fine cheers :y :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: display
« Reply #4 on: 01 January 2012, 19:41:37 »
I get this everytime I turn ignition on. Just think it's set like that
RIP Paul Lovejoy
GLENNY BOY
  • dartford
Re: display
« Reply #5 on: 01 January 2012, 20:22:06 »
oh great its not just me then its never done this before until 29th dec i thought strange ::) my mate checked lights while i apply the brake all working so i dont understand why its happening its a fault on rear lights  ::) ::)
Re: display
« Reply #6 on: 01 January 2012, 20:22:39 »
You're supposed to. The message appears, you press the pedal & if both brake lights come on the system is happy & extinguishes the message. If a lamp fails, you get the message to inform you that you need to buy a new lamp.
GLENNY BOY
  • dartford
Re: display
« Reply #7 on: 01 January 2012, 20:25:16 »
thats what im saying its saying brake light which i thought means you need a bulb but my rear lights are working so why is it telling me to check brake light when lights ok  :y :y
Re: display
« Reply #8 on: 01 January 2012, 20:28:25 »
When you first turn your ignition you should get the message .... brake light check. When you press the brake pedal the message goes away assuming that both brake lamps are working. If you get the message appear during normal driving it means that a brake lamp has failed or you've fitted cheapo brake lamps or there's a fault in the check system (unlikely)
Webby the Bear
  • Northampton
Re: display
« Reply #9 on: 01 January 2012, 20:36:38 »
Cheers Andy B. That clears that up!  :y
RIP Paul Lovejoy
GLENNY BOY
  • dartford
Re: display
« Reply #10 on: 01 January 2012, 20:38:09 »
well thats what its saying after system check,i drive then the display says BRAKE LIGHT but brake lights  are all working fine so yes im puzzled  ::)and its just started doing it and bulbs were from halfords so no rubbish ones and been in ages
« Last Edit: 01 January 2012, 20:41:15 by GLENNY BOY »
Re: display
« Reply #11 on: 01 January 2012, 20:40:35 »
well thats what its saying after check, BRAKE LIGHT brake lights all working fine so yes im puzzled  ::)and its just started doing and bulbs been in ages
There`s your problem
GLENNY BOY
  • dartford
Re: display
« Reply #12 on: 01 January 2012, 20:41:58 »
what is  ::)
Re: display
« Reply #13 on: 01 January 2012, 20:42:46 »
Agreed! Go and buy & fit a pair of QUALITY stop/tail lamps.  ;) ;) ;)
Re: display
« Reply #14 on: 01 January 2012, 20:43:35 »
what is  ::)
'BULBS BEEN IN AGES' is your problem!  ;) ;)
