Author Topic: 3.2V6 breathers  (Read 2871 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
3.2V6 breathers
« on: 02 January 2012, 18:46:56 »
Having read the guide, at what frequency is it recommended to clean these?
Welung666
Re: 3.2V6 breathers
« Reply #1 on: 02 January 2012, 18:52:10 »
I'd recommend doing them annually.
Shackeng
  • Ramsbury
Re: 3.2V6 breathers
« Reply #2 on: 02 January 2012, 18:53:42 »
Cheers Lee, I am only doing about 3000m a year in the 3.2, does that still apply?
Welung666
Re: 3.2V6 breathers
« Reply #3 on: 02 January 2012, 18:56:03 »
Even more so in your case, lower mileage will greatly increase condensates to form in the breathes.
Shackeng
  • Ramsbury
Re: 3.2V6 breathers
« Reply #4 on: 02 January 2012, 18:58:00 »
B*&%@r, yet another job to do this winter :y :y :y
Re: 3.2V6 breathers
« Reply #5 on: 02 January 2012, 19:25:47 »
Once they have been properly cleaned out once, I just check them every oil change. Remove the pipes at the rear of the plenum cover and, by blowing down a length of hose, check each breather is clear both up towards the plenum and down to the breather box. A squirt of carb cleaner into each for good measure and leave it at that, if all appears well.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: 3.2V6 breathers
« Reply #6 on: 02 January 2012, 19:30:55 »
If you take Kevins advice do you have to do an oil change having injected carb cleaner and does a long run now and again help to clear the breathers
Re: 3.2V6 breathers
« Reply #7 on: 02 January 2012, 19:35:41 »
A little squirt of carb cleaner (i.e. not a whole can) will do no harm. I just do it with an oil change by routine.
A long run will indeed help, as it removes all moisture from the crankcase if the oil is hot for an extended period of time.
Shackeng
  • Ramsbury
Re: 3.2V6 breathers
« Reply #8 on: 02 January 2012, 23:10:55 »
Thanks KW. :y
Re: 3.2V6 breathers
« Reply #9 on: 03 January 2012, 11:17:09 »
Indeed, I do mine annually (in the summer!) along with TB clean etc.
For shorter journeys, I'd probably consider 3 times a year, esp if the oil you use has a habit of mayoing on shorter runs (check oil cap)
Shackeng
  • Ramsbury
Re: 3.2V6 breathers
« Reply #10 on: 03 January 2012, 11:23:08 »
 :y :y :y
