Author Topic: engine breathing  (Read 1420 times)
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
engine breathing
« on: 03 January 2012, 15:41:11 »
 hi all
would drilling a hole in the oilfiller cap & puting a pipe in
 help with engine breathing
 any comment would be helpfull
                                             ozzy
long live the magic tree
its good to be back
Welung666
Re: engine breathing
« Reply #1 on: 03 January 2012, 15:49:18 »
In a word, no! The breathing system is more than adequate as long as it's kept clean.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #2 on: 03 January 2012, 15:52:15 »
This - regular cleaning is all it needs.
ozzycat
    • hyundia i30
« Reply #3 on: 03 January 2012, 16:10:06 »
 this was in addition to regular cleaning
its good to be back
Welung666
« Reply #4 on: 03 January 2012, 16:16:01 »
It'll make no difference other than reduce crankcase pressure. The system is fine as it is.
« Reply #5 on: 03 January 2012, 16:23:06 »
Doing the above will effectively give you an air leak as the engine casing is connected to the inlet via the breathers.
ozzycat
    • hyundia i30
« Reply #6 on: 03 January 2012, 16:26:42 »
 :y :y :y ok i will leave well aloan thanks for your  help  :y :y :y :y
     ozzycat
its good to be back
« Reply #7 on: 03 January 2012, 17:42:00 »
Some tradesperson did this to a 2.5 omega thinking it would solve the breathing problem ...all it did was blow oil out the drilled pipe exit cos the breathers were never cleaned  ::) ::)
