Author Topic: Xenon light has gone to the dark (pink) side  (Read 4686 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 03 January 2012, 16:55:58 »
It seems that my car want to join the Darth Lorraine Kelly club as one of the xenon lights went pink.  The car must have known it was the MOT today as well as it was okay yesterday (grr)
It starts off white and then turns pink after a few seconds, so is this the bulb or the ballast?
Also where is best to get replacements from?
Re: Xenon light has gone to the dark (pink) side
« Reply #1 on: 03 January 2012, 17:24:08 »
Pass?!?
Try swapping bulbs over.
If you move the fault - it's the bulb.
If the fault stays put it's something else/ballast.  :y
« Reply #2 on: 03 January 2012, 17:24:19 »
It's the bulb on its way out. Buy a branded pair to replace them ;) :y
« Reply #3 on: 03 January 2012, 17:26:25 »
Indeed, classic bulb failure. Probably original. Replace in pairs, you will realise how back the old bulbs had got.
From memory, OE are 4500k.
    • E250 Est / Elroq
« Reply #4 on: 03 January 2012, 17:27:09 »
deffo bulb
phillips or osram, 4300, 5000k, or 6000k at a push, no higher :y
« Reply #5 on: 03 January 2012, 17:44:38 »
I wouldn't go above 5000K unless you want to look like a cap wearing shandy drinker......ow yes, its guffer isnt it  ;D
« Reply #6 on: 03 January 2012, 17:56:52 »
Ooh - I like that one. ;D ;D ;D ;D 8)
« Reply #7 on: 03 January 2012, 17:58:15 »
Wots wong wif caps, and wots wong wif shandy?
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
« Reply #8 on: 03 January 2012, 18:46:35 »
I got mine from http://www.hids4u.co.uk
About £65 for the pair IIRC.  ;)
The happiest people don't have the best of everything,
they just make the best of everything they have.
Gaffers
« Reply #9 on: 03 January 2012, 20:17:16 »
Havent you got a hornby trainset to go play with  :P
« Reply #10 on: 03 January 2012, 21:04:45 »
Indeed I have, hows the balsa wood boat captain pug wash  ;D
Gaffers
« Reply #11 on: 03 January 2012, 21:09:06 »
Funny you should mention the mistress 'Jenny' as I have made good progress over the last few weeks.  She now has a cabin and a roof and is now waterproof above and below the waterline.  Just leaves the cockpit to fit out and then a decent paint job and she's done.
I tell you what though, bending 9mm marine ply along the grain over the roof structure was a little bit challenging to say the least!  ;D
« Reply #12 on: 03 January 2012, 21:12:01 »
Although I am actualy doing bits on the Tractor this evening, a bit of fiddling with a nice smooth bush.
I do have a spare genuine brand new HID bulb by the way, no use to me if you want it.
Gaffers
« Reply #13 on: 03 January 2012, 22:31:40 »
Thats a very kind offer Mr DTM  :y
I may take you up on that, I'll let you know tomorrow if I do ;)
Gaffers
« Reply #14 on: 06 January 2012, 18:41:13 »
Fitted new bulbs today and break me I am nearly blind they are so bright!  I went for the 6000k in the end and they look good, the light is excellent.  I guess the old ones had really deteriorated and I hadn't noticed  :-[
