Author Topic: Smell of petrol, where to get it fixed in Bedford?  (Read 1451 times)
SalahJ
  • Bedford
    • Gold 2001 Omega Elite 2.6
« on: 05 January 2012, 22:48:42 »
My omega (2001 Elite 2.6V6 Auto Petrol) smells of fresh petrol inside when stopped in traffic, the smell is even stronger outside and under the bonnet. Fuel consumption is also gone up a fair few bit. I'm not a car nut so can anybody please suggest a garage in Bedford where I can go and get it fixed (without getting ripped off)?
Thanks.
« Last Edit: 05 January 2012, 22:50:29 by SalahJ »
Re: Smell of petrol, where to get it fixed in Bedford?
« Reply #1 on: 06 January 2012, 04:48:29 »
You may wait have to wait some time before someone local to you who knows a good garage reads your post.
It sounds like you dont have time to wait.You have a fuel leak which could easily be very dangerous. My advice would be to ask friends,family neighbours etc. to recommend a mobile mechanic who can come to you,so that you dont have to drive the car until its fixed. It sounds as though it isnt safe to be used until its had diagnosis of the problem.
SalahJ
  • Bedford
« Reply #2 on: 06 January 2012, 09:31:26 »
It's difficult for me to get to work without the car. Nothing can be smelt when it's moving. After driving it when I come out of the car I can smell the petrol but it goes away after a few minutes. Also the car is driving fine without any warning lights or such.
I'll wait for any Bedfordian member comes along and suggest me a garage.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 06 January 2012, 11:32:46 »
I am not sure there is a warning light for ''your car is about to become a fireball''!
Albs has already pointed out that you have a potentially dangerous problem that needs immediate attention so get it sorted before you drive it.
Safety first.
RIP Paul Lovejoy
« Reply #4 on: 06 January 2012, 12:57:32 »
The reason that it doesn't smell when moving is that you have a better supply of fresh air. It'll still be leaking.
A fuel leak that you can smell should be visible. Have a good look under the bonnet, and also follow the fuel lines down inside the driver's side wheel arch and along the bottom of the car - they are easy to find. Do this with the engine running and see if you can spot any moisture anywhere.
Also, lift the boot carpet and you will see a round silver plate with 4 screws in it. Remove this and look at the connections to the fuel tank there. Often the pipes here get leaky.
As for a local garage recommendation, I agree that people you know living locally would probably give a quicker answer but someone here might be able to help.
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #5 on: 06 January 2012, 13:03:57 »
check under rear of car too where tank is mounted for tell tale wet areas, i know my tank leaks if more than 20lts fuel put in it but thats thanks to the idiots who fitted lpg sticking a drill thrrough it, just got to wait for it to empty before i can drop it off and fix
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
SalahJ
  • Bedford
« Reply #6 on: 06 January 2012, 13:25:00 »
Thank you all for all your sugguestion. I'll check the boot carpet tomorrow and also I'll ask around my work place if anyone knows about any garage.
I was reading another members post who had similar problem.Here's the post - http://www.omegaowners.com/forum/index.php?topic=97755.0
Shall I check/replace the pollen filter as suggested in above post?
martin42
« Reply #7 on: 06 January 2012, 17:05:34 »
try avon drive garage,i take my cars there for mot,ask to see phil 1st and say martin,who has the silver omega told you to see him,he will sort you out and not rip you off
Avon drive mot and service centre
Avon drive
Brickhill
Bedford
MK41 7AF
tel 01234 342077
« Last Edit: 06 January 2012, 17:12:20 by martin42 »
SalahJ
  • Bedford
« Reply #8 on: 06 January 2012, 19:59:30 »
Avon drive
Brickhill
Bedford
MK41 7AF
tel 01234 342077
Thanks a lot Martin. I'll talk to Phill as soon as I can. I really appreciate your help.
