Author Topic: Fault code 23  (Read 1688 times)
rossi123
  • St Helens Lancashire
Fault code 23
« on: 07 January 2012, 12:30:30 »
Hello everyone just got a fault code 23 replace servotronic ecu anyone any ideas ?? 8(
Re: Fault code 23
« Reply #1 on: 07 January 2012, 12:33:14 »
Never seen that one before.
Is it 'present'
Can it be deleted and if so, does it come back?
rossi123
Re: Fault code 23
« Reply #2 on: 07 January 2012, 12:44:01 »
If you clear it, it comes back ?? I was thinking that maybe it meant the servotronic relay ??
Re: Fault code 23
« Reply #3 on: 07 January 2012, 16:22:18 »
What ECU are you reading? I would have thought it would have to be the servotronic ecu to give that code....which personally ive never been able to communitate with using a reader like yours.
Re: Fault code 23
« Reply #4 on: 07 January 2012, 16:23:20 »
remind me your car engine and year please...
Re: Fault code 23
« Reply #5 on: 07 January 2012, 16:28:00 »
Any PAS related problems / symptoms ?
Re: Fault code 23
« Reply #6 on: 07 January 2012, 16:46:32 »
the TIS guidance merely states :
Defective component:
K41 Control Unit - Servotronic
Its up behind the glovebox, sure theres a pic in the maint guide and a breaker could supply if needs be.
1st one Ive heard of with an error though!
Re: Fault code 23
« Reply #7 on: 07 January 2012, 16:51:10 »
I (and others) have supplied them to people on request,so presumably they can give problems. Pretty sure it would be accompanied by PAS problems rather than just a fault code though.
Around £80 new from VX iirc, which is rather shockin for a relay. :o
rossi123
Re: Fault code 23
« Reply #8 on: 07 January 2012, 19:15:57 »
The steering has gone very stiff which is obviously a side effect of the relay being goosed thanks ever so :)
rossi123
Re: Fault code 23
« Reply #9 on: 07 January 2012, 19:17:17 »
Jimbob this is my new car it's s reg and 3.0 ltr
