Author Topic: cut out on the M62  (Read 2182 times)
Ken T
  • Stockport
cut out on the M62
« on: 10 January 2012, 21:48:21 »
Greetings,
I was driving home tonight, just got to the road works section with the hard shoulder coned off  :P , and the spanner light came on. I didn't notice if I was in limp mode as I was going down hill at 50mph. Within 30 secs or so she cut out and I had to coast to the next junction. I got onto the hard shoulder, and within 1 or 2 spins she restarted. I set off again, spanner light out, OK for a couple miles then cut out again, she restarted with 3 or 4 spins. Another 2 cut outs until home, however after 1hr rest she starts fine. I read the codes and got P0340 (8 ), P0340 (4), and P0335 (?). I was running on LPG at the time and didn't think to change to petrol. Any ideas ?, could it be the dreaded crank sensor ?.
Ken
« Last Edit: 10 January 2012, 21:56:46 by Ken T »
Re: cut out on the M62
« Reply #1 on: 10 January 2012, 21:54:19 »
The codes suggest so......and so do the symptoms!
Ken T
  • Stockport
« Reply #2 on: 10 January 2012, 21:58:02 »
Thanks, I was getting confused with the P0340. Looks like a trip to Jct 600 dealers tomorrow.
Ken
« Reply #3 on: 11 January 2012, 19:39:03 »
If the calibration was a long way out, causing a bad misfire, could that throw a spurious crank sensor?  Personally doubt it, but odd to see both crank and cam sensor faults on V6 (it is a V6, isn't it?)
And if calibration, there would be a trim code...
(if its a 4 pot, both cam and crank sensor fubar)
Ken T
  • Stockport
« Reply #4 on: 11 January 2012, 20:41:07 »
She's been running on LPG OK, reasonable acceleration, a bit down at high speed we haven't got it mapped properly, ( duff laptop battery !) however a new battery arrived a couple of days ago so will try and match up LPG and petrol.
I managed to get a new sensor, JCT 600 didn't have any so  I had to get one from Autovaux. In preparation for it failing soon, I will order one from Andy C.
Ken
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #5 on: 12 January 2012, 08:13:20 »
more engines fail when there are road works, all the stopping and move a few feet then stopping again, herd other day there were 8 cars broken down on m62, within 15min's.
Solar charger fitted.
If not Broke dont fix it..
Ken T
  • Stockport
« Reply #6 on: 12 January 2012, 20:10:15 »
I fitted the new crank sensor, and set off this morning, and.......
After about an hour, same again, spanner first then she cut out. I managed to get onto the hard shoulder and she restarted fine, but felt a bit rough. I read codes at lunch time, same again, P0340, P0340 and P0335. And tonight, after about 1 hour, spanner light came on, and then a surge like fuel cut off and then re supplied, happened a few times. I changed over to petrol for a couple miles then back to LPG and she was fine for the last 30mins or so. This is wierd, I will try and remember to make sure I am on petrol 60mins after setting off, to see if its LPG related.
Ken
Page created in 0.04 seconds with 16 queries.
