Changing the interior colour
Started by blackviper90210, 11 January 2012, 08:00:44
blackviper90210
A fellow OOfer is looking to changing the interior colour of his mig...
Do you change the carpet too or is that a too much pain in the arse job? I've got the cream leather & carpet, would the black leather look "right" with cream carpets still, or would it be best to change the carpet too?
TIA :y
AKA - Mr Bracket
Quote from: blackviper90210 on 11 January 2012, 08:00:44
TIA :y
Done this on a member`s car (cream to black). Ideally you need to change (as well as the seats) the following. Pass. glovebox, driver`s cubby hole, doorcards, seatbelts, rear shelf, lower trims, (front kickpanel, sill covers etc) and carpet. Everything`s a doddle Dave
blackviper90210
And there was me hoping for a simple of answer of....... just change the seats ;D ;D ;D ;D ;D ;D
Well this will be going on the list of jobs to do this year then!
What about the carpet though, is that an easy task or just time consuming? ???
AKA - Mr Bracket
If the seats and other bits and pieces are already out changing the carpets will take about 5 minutes. :y
The Red Baron
its not really that much of a pain to do tbh Dave, a pretty straightforward job. :y
Quote from: blackviper90210 on 11 January 2012, 09:15:28
Seats out, lower trims out, lower seatbelt mounting undone, carpet`s in two pieces stapled together under seats. Rear piece just lifts out, front piece has two holes in it either side of centre transmission tunnel that hook on clips under console, slight yank and it`s out. When re-fitting just tuck the carpet edge under console
blackviper90210
Mmmmmmmmm, food for thought. Cheers for the advice guys :y
AKA - Mr Bracket
TBh,the hardest part of changing an interior imo is changing the doorcards.
blackviper90210
True, not the easiest bits to remove without breaking!  ::)
AKA - Mr Bracket
2woody
hardest part has got to be the rear parcel shelf, surely.
But - it all depends on how well the change needs to be completed.
if it's just seats then its easy, but if its a whole interior change then it's really quite difficult, extending to parcel shalf, door cards, centre console, cant rail covers, headlining, the list is quite long.
Quote from: 2woody on 11 January 2012, 10:57:56
Easy :)
One other thing to bear in mind Dave. Yours being the 3.2 Elite will most probably have the child seat sensor, if you replace with a non-sensor seat you will have to change the main SRS ECU as it`ll be configured for the CSS and I`m fairly sure TechII can`t change it.
blackviper90210
I don't know if it is fitted with the sensors so will have to check, thanks for the heads up on that point though! :y
AKA - Mr Bracket
SJKOO01
Dave,
I've done this on mine, so if you need any help with helping out a fellow OFFer give me a shout and I can always help / advise to speed things up on the change over  :y
Quote from: blackviper90210 on 11 January 2012, 14:56:59
Most of the 3.2 Elites had them fitted Dave, should be a sticker on side of seat, or look underneath and if you have a yellow flat rectangular plug about 50mm x 25mm x 6mm connected to the seat module it has a CSS
