Engine Oil amount
Started by MV6Matt, 11 January 2012, 12:18:48
MV6Matt
Will be changing the oil and filter friday
How many litres do I need?
Matthew
(thanks Ian)
Webby the Bear
Depends on size of engine I believe.
Mine's 2.5 v6 and will take 5.5 so I need two bottles :y
RIP Paul Lovejoy
Quote from: MV6Matt on 11 January 2012, 12:18:48
Matthew
Missing rather important bit of information here.... what engine  :y
4pots 5L
V6 5.5L
5.75 Litres required on a V6. ;)
MV6Matt
...Thanks for the replies, yes I did leave out the rather important info didn't I? :-[
It is indeed a V6 petrol engine, so 5.5/5.75 litres it is!
many thanks
Matthew
(thanks Ian)
MV6Matt
......Nice to enjoy some benefit from ordering with T/C.......
6 litres oil and a Filter down to 21 notes from nearly 50! :y :y
.......I need to get out more.....................
(thanks Ian)
Spend another £15 and get an extra 14 litres :y
Webby the Bear
RIP Paul Lovejoy
Webby the Bear
Ps I got a few 'O' rings from the stealers today for the drain plug (plus filter and oil) and he asked if I wanted the copper ones or rubber.
I went for rubber. That ok?
RIP Paul Lovejoy
Radar
You could always change to the hex t45 nut which is more durable and can be reused for a good few changes.
Webby the Bear
Quote from: Radar on 11 January 2012, 16:21:16
I'll be honest I can't remember what nut I've got already!
I went for rubber as that's what I thought it was when Daz did my service.
RIP Paul Lovejoy
Radar
If you have a nut that is hexagonal in shape then you need to have a copper/rubber nut.
The one i referred to is a round nut with a t45 size indentation.
Webby the Bear
ill check tonight what ive got  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 11 January 2012, 16:23:21
Two hopefully :D
twiglet
Quote from: RobG on 11 January 2012, 16:33:33
Two hopefully :D
Great minds Rob...  :D ;D
