Author Topic: 2.6/3.2 Inlet Manifold and Injectors  (Read 3633 times)
twiglet
  • Norwich, Norfolk
« on: 11 January 2012, 16:22:06 »
Can anyone confirm whether the 2.6 and 3.2 engines use the same inlet manifolds and injectors please?
TIA  :y
Re: 2.6/3.2 Inlet Manifold and Injectors
« Reply #1 on: 11 January 2012, 16:24:10 »
Different manifold, I think injectors may be different also :-\
Intake manifold for 2.5/2.6 is 90469820
Intake manifold for 3.0/3.2 is 90469821
twiglet
  • Norwich, Norfolk
« Reply #2 on: 11 January 2012, 16:25:20 »
That answers that one then!!  :y
« Reply #3 on: 11 January 2012, 16:26:13 »
Recall several posts from those that know that the 3.2 injectors are larger than 3.0, but not sure if 2.6 are the same as 3.2  :-\
« Reply #4 on: 11 January 2012, 16:27:07 »
Injectors are:
X25XE/X30XE:
Part no 30487344
Y26SE/Y32SE:
Part no 24406653
So that answers both ;D ;D
twiglet
  • Norwich, Norfolk
« Reply #5 on: 11 January 2012, 16:38:00 »
Seems very strange to me the the 2.6 and 3.2 use the same injectors, yet different manifolds...
Would be interesting to know exactly what the difference is between the manifolds.  Am I right in thinking that the bridge and plenum are the same on both engines?   :-\
« Reply #6 on: 11 January 2012, 16:51:25 »
Different lower dividers = different manifolds.
2.5/2.6 is 90467003
3.0/3.2 is 90467004
I`ll pass on the bridge & plenum ;D
« Reply #7 on: 11 January 2012, 17:09:57 »
2.6/3.2 same plenum and same inlet/injector assembly. :y
The plate that connects the inlet/injector assembly to the heads is different, as Rob has highlighted so eloquently above :y
just to add, same throttle body too :y
« Reply #8 on: 11 January 2012, 17:59:13 »
My understanding was the same as Al has said.If they have different part numbers though ?  :-\
twiglet
  • Norwich, Norfolk
« Reply #9 on: 11 January 2012, 19:27:51 »
Well it's confused.com here I'm afraid.  :-\
« Reply #10 on: 11 January 2012, 19:43:14 »
But thats nothing new. :P :D ;D
« Reply #11 on: 11 January 2012, 19:58:47 »
The cast inlet is different between 2.6 and 3.2 ;)
twiglet
  • Norwich, Norfolk
« Reply #12 on: 11 January 2012, 21:42:22 »
Oi! Listen here you... hang on, who are you? where am I?  :D :P
twiglet
  • Norwich, Norfolk
« Reply #13 on: 11 January 2012, 21:43:01 »
Cheers TB.  :y  See, still learning!  ;)
« Reply #14 on: 13 January 2012, 04:47:59 »
My original 3.2 one was swapped out with a 2.6 one (apparantly), (bought from Steve at Omegaspareparts when an injector sprung a leak).
Absolutely no difference whatsoever: same loom/same injectors/same casting :-\ Side by side I couldn't see any difference between them :-\
