omega flat battery
Started by nw2cacc3, 12 January 2012, 12:55:24
nw2cacc3
My omega battry is continually be drained by something, any ideas?
Dave DND
Try disconnecting the alarm powersounder under the scuttle panel
Radio & Decoding Technician
www.dndservices.co.uk
freecall666
Solar charger fitted.
If not Broke dont fix it..
fiend61
#3
check voltages running and not running could be that alternator not charging battery enough, are you doing lots of short runs etc what is the time span of the battery draining? overnight? couple of days ?
could be any number of things from duff battery, alternator not giving enough charge,  power sounder draining it, glovebox light or boot light stuck on
you really need to get a meter on it and post up voltages  :y
SIR Philbutt
Had a stuck passenger seat adjust switch that caused this once - does not go off with ignition so would drain overnight
Found it when eventually heard the seat "clunking" against the stop
worth looking at
Quote from: Philbutt on 12 January 2012, 16:09:33
..... does not go off with ignition so would drain overnight
They should do ......... eventually. Opening the door wakes them up for a few minutes, and they stay awake for a few minutes after you've switched the ignition off. Stay in the car when SWMBO goes shopping & play at moving the seat  :y :y
SIR Philbutt
Quote from: Andy B on 12 January 2012, 16:16:11
my mistake - made an assumption then posted it on here - silly me  ::)
Still battery didnt got flat again after that  :o
By the way never go shopping with swmbo toooo booooring  :y
Stallion
Quote from: Philbutt on 12 January 2012, 16:21:28
;D ;D ;D
