Author Topic: Diagnoise Radiator leak  (Read 5793 times)
BigAl
  • Bromley, Kent
    • '07 Forester
« on: 15 January 2012, 15:17:55 »
Guys,
My 2.6 started leaking coolant earlier this week, since then i have done 2 short journeys yesterday -each about 5 miles after each one I have to top up the coolant as the expansion bottle was almost empty, checked what i could
to find the leak and couldn't - the water was dripping from the hole in the cross member directly below the drivers side of the rad.
So today i removed the rad, which is quite easy - until you start dropping bolts in the engine bay. I now have it on the kitchen table and cant find any obvious signs of damage- any pointers or ideas how to troubleshoot this ?
Cheers
Al
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Diagnoise Radiator leak
« Reply #1 on: 15 January 2012, 15:25:10 »
Sometimes the rad will only leak under pressure, usually they go at the sides, where they are 'crimped' together...
« Reply #2 on: 15 January 2012, 16:37:30 »
Agreed  :y
Mine wouldn't leak until the car had been driven, then under pressure the rad leaked from a hairline crack on passenger side of rad .. leaked half the header tank on a small journey but only leaked after i had stopped  ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Diagnose Radiator leak
« Reply #3 on: 15 January 2012, 17:06:39 »
Have you considered 'pressure testing' it?
Get a cheap mountain bike inner tube, and cut it opposite the valve. Attach each end to the radiator outlets. Pump up to 14psi with a bike pump. Leave for a couple of hours, and recheck the pressure.
Do not, under any circumstances, leave in your front garden so that some theiving scum can help himself to your property!
RobseyMV6
  • west sussex
« Reply #4 on: 15 January 2012, 17:24:16 »
You sure its that and not HBV? know you spotted coolant/water there but maybe just happen to be water laying there?
You should really have seen if was leaking by marks of coolant, have a look at the HBV for water marks...
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« Reply #5 on: 15 January 2012, 18:21:01 »
I have a coolant leak also and assumed it was the HBV so have elite pete change it today. Turns out to be coming from the pipe going to the hater matrix thats visible to the left of the hbv. Has anyone else had this?
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #6 on: 18 January 2012, 15:04:42 »
Thanks for all the suggestions - i will try the inner tube trick tonight and see what happens.
with an eye on replacement, i spoke to my local garage who quoted £300 for genuine & £230 for pattern both seem expensive, so i have had a quick look on the net and found the following:-
http://www.adrad.co.uk/ have a GM463 replacement delivered for just under £100.
http://www.onlineautomotive.co.uk have a replacement delivered  for £150.
anyone got any advise/views pointer on where to go what to avoid
Cheers
Alasdair
« Reply #7 on: 18 January 2012, 17:58:53 »
Got mine off bay of fleas £45 delivered ...used part mind but needs must , £300 from local garage ? Begs the question how much it would be new from VX  :D
« Reply #8 on: 18 January 2012, 18:07:13 »
Cheers
Alasdair
http://www.carcooling.co.uk/catalog/Vauxhall_Omega_B_94_03-1245-2.html
« Reply #9 on: 18 January 2012, 18:27:02 »
 Retail    Trade    Trade Club
 £262.00    £209.73   £185.50   +vat    :y :y :y
« Reply #10 on: 18 January 2012, 18:30:27 »
 :D :D :D :D :D :D WOW     ...still thats cheaper than the original local garage cost  ::)
« Reply #11 on: 19 January 2012, 18:07:32 »
Cheers
Alasdair
Had two from these people (for different cars!) - quick delivery and no probs since fitting. :y
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #12 on: 21 January 2012, 14:58:32 »
right tried the inner tube trick - how do you keep the tube on the radiator ?
I tried using the clamps for the hoses but it is far too loose
Cheers
Al
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #13 on: 21 January 2012, 17:58:06 »
scratch that - found some hose clips that fitted and can confirm the rad is leaking somewhere from the drivers side, I will strip the rad totally tomorrow and investigate further
Al
  • Chatham, Kent
« Reply #14 on: 21 January 2012, 21:04:49 »
Cheers
Al
The inner tube is thinner than the radiator hoses, so the original clips won't work. Bin the useless spring clips and use proper worm drive ones. Jubilee is the usual and original brand, but not the only one. They're easier to fit/remove and give a reliable and adjustable clamp to anything but the very smallest hoses. The spring ones are used simply for quick assembly, and for no other reason.
Page created in 0.025 seconds with 16 queries.
