Wanted: Screen washer tank filler neck
Started by Shackeng, 15 January 2012, 18:02:29
Shackeng
As above from a preface or MFL car.
TIA :y
Quote from: Shackeng on 15 January 2012, 18:02:29
TIA :y
Someone going to do Broocies mod ???
I've been watching for one for a while and not seen any .. good luck with your request ... :)
amba
Not sure if this helps  ;D ;)
380120738691...off the bay of fleas :y
Shackeng
Ta, I'll have a look. Actually Nige, it was you that suggested to me! :y
GastronomicKleptomaniac
Quote from: Entwood on 15 January 2012, 21:36:39
hotel21
Quote from: GastronomicKleptomaniac on 17 January 2012, 14:03:24
The bonnet slam panel on the facelift is the same as the pre/mini facelift and thus has the washer filler hole.
But, on facelifts, the filler is in behind the grille area and so, when viewed from the front, your nice black irmscher/whatever grille has a yellow blob of cap in view through it.
Fit a prefacelift filler neck, slightly heated and bent to shape, with a length of suitable size hose and the filler goes onto the slam panel up and out of sight.
Another post where a piccy tells it better but, hope you get the gist....   :y
Quote from: hotel21 on 17 January 2012, 19:49:19
Aha! Makes sense, ta B.
joff
Just ordered one from OmegaSpareParts just over £5 with postage :y
