heater, cd player and speedo gauges don't work
Started by Kosaisan, 16 January 2012, 21:55:10
Kosaisan
Hello sorry for my bad english
I have a bit of a problem here the heater on my car dont work anymore there are no power the same goes for the cd player and the speedo gauges along with the infoscreen.
what seems to be the problem?
Kosaisan
Yes I checked all the fuses and they all seems oki.
The strange part is the only that works inside the car is the light on passanger side in the back.
And the fan on heater goes on and off when the car is off.
jonny2112
Sounds like something more sinister, and beyond my limited knowledge!
Have you carried out any work on the car, or had battery disconnected?
Kosaisan
I was just changing my window wipers. I tryed to disconnect the battery without any luck..
jonny2112
Sounds like something has maybe become disconnected or trapped. Were you changing the wiper blades? Or why would you have tried to disconnect the battery?
Kosaisan
I was changing the blade when I heard the heater going on and off for about 10 seconds. I tryed to disconnect the battery when I released the problem to see if it would help..
It's kind of problem without the climaet since it's up her in north of Norway
jonny2112
Quote from: Kosaisan on 16 January 2012, 22:43:32
I can imagine!
Was anything disturbed when trying the battery? Strange that there is some power in the cabin?
Kosaisan
No not as I can think of. The only strange thing in cabin is the light above the passenger on in the back starting to go on when I open the door.
