Author Topic: Is there a knack to removing the heater hoses from matrix.  (Read 1955 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Seen the maintenance guide about pushing in clip and turning then pulling but mines don't wanna come off.
Re: Is there a knack to removing the heater hoses from matrix.
« Reply #1 on: 19 January 2012, 13:49:40 »
I had the same yesterday.Finally found that if you oush the locking rings forward until they actually come off the end of the hose,the hose will then pull off.The ring can then be put back on after you have pulled the hose off. :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #2 on: 19 January 2012, 14:01:32 »
cheers
« Reply #3 on: 19 January 2012, 18:23:23 »
If you don't have the green plastic ring in place, you will find it a challenge.
« Reply #4 on: 19 January 2012, 18:25:42 »
I noticed those dangling loose from my matrix pipes.Wondered what they were. ::) ;D
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #5 on: 19 January 2012, 19:41:54 »
Thats sitting loose behind the pipe. on the top hose.
« Reply #6 on: 19 January 2012, 19:51:31 »
Push it up against the mechanism (it shoudl fit in a certain place), when you push the black part of the clip back, the green bit assists it to unclip.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #7 on: 19 January 2012, 19:53:38 »
How do I get the feeling this is going to be fun.
« Reply #8 on: 19 January 2012, 19:54:09 »
Actually, I think I'm talking 'dangle berries' ;D
Ignore me completely, I think the green ring is to assist getting back on ;D
Its been a while since I've done one  :-[
« Reply #9 on: 19 January 2012, 19:54:53 »
Matchless's guide is bang on, except use green ring to help getting back on. I smeared in vaseline to get it on as well.
  • Auckland
    • Mazda MPV
« Reply #10 on: 19 January 2012, 19:56:19 »
On my early (1994) Omega I found that mine had bonded themselves to the heater pipes. Once I had broken the seal they worked as advertised but it was a real struggle to get them moving in the first place.
« Reply #11 on: 19 January 2012, 20:47:59 »
Rotating helps break seal between hose and alloy pipe.
Page created in 0.071 seconds with 16 queries.
