Author Topic: MV6 Estate S,L suspension issues ex,police HELP ASAP!  (Read 1660 times)
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« on: 19 January 2012, 19:41:55 »
HI ive got a 99v ex police mv6 estate 3.0, as the ride hight on police spec springs were huge i.e 4"+ from 225 60 15 tyres to wheel arch i found a set of imrscher red springs & front struts for £20 in a scrappy ive fitted them onto car but in doing so 1 of the rear self level shocks sheered the top pin off with an almighty bang spraying fluid everywhere! i bought off ebay a pair of monroe air assist rear shocks with pipe & guage, i removed fuse from S,L kit & after fitting them & doing what kit instructions said on test drive Very bouncy & loud knocking from rear even with guage at max in green section? i called irmscher & they said there kits are 25/30mm max drop over standard & the mv6 model is already 15mm lower as standard..? but i noticed a huge drop of 40mm on front & 60mm on rear from police spec springs but the car sits perfectly level  :)  But as shockers were still knocking  i called monroe who said that the shocks are only designed to fit cars with standard ride height & do not fit a standard mv6 & they dont list a shock for an mv6 either... ive tryed everywhere to source standard s,l shocks but priced at £180 each +vat! i calnt find anybody who do a standard mv6 shocker that can accomadate a drop of any height...? speaking to PVD, Vauxhall, LMF Vauxhall, Courtney sport etc they say only Bilstein do a B6/B8 shocker or a B12 complete kit for it now with 4xB8s & eibache 30mm springs £618.00 or FK coilovers £575.00 .... Dont know what to do... i use the car for 4 things... 1 daily driver, 2 drift racing & track days, 3 work car which means hauling upto 250kg in the boot, 4 towing a 3500kg car trailer so the S.L kit perfect & coil overs i can raise rear via spanners or use s,l to stiffen it up stop it goin too low but its trying to find a setup for all uses that dont cost a fortune... i want to try keep the drop ive got if poss just need to stiffen rear up as im running frontera front dampers modifyed to fit atmo so i can use car with small airbags wiv shraider valves but they are 20years old & 1split in bham goin over a speedbump & left rear on a rounderbout lastnight & now its bouncy again & knocking!! the airbags worked perfect if they were a bit bigger coz i cud maybe mod them into s.l system & when i have weight in rear pump them up but i still need 2 rear shocks to work lowered or raised or would standard s.l do it if i angle the sensor on rear wishbone not to raise it too high? because i got a 2nd hand one fitted them both on but as it was pumping up they lifted the car over 5" from tyre to arch then the 2nd had one blew & when deflating its self back down after the old one then blew aswel so i couldnt test the theory... i hope this kinda makes sence?? could i have a contact number if replying or if easyer mine is 07534 967604 as this is my 1st message & unsure how it all works...? hope you or anybody else can help..? Oh BTW car is now sat on 17" alloys with 225,45,17 fronts & 245 40 17 rears, from the 225 60 15 original steels that police had fitted.
« Last Edit: 19 January 2012, 19:57:41 by Zippy2012 »
Latchie_3.0v6
  • OMAGH N.IRELAND
    • Omega 3.0 v6 elite (sold)
Re: MV6 Estate S,L suspension issues ex,police HELP ASAP!
« Reply #1 on: 19 January 2012, 20:17:55 »
Don't know if this helps but a boy in northern Ireland does coilovers for omegas at £325 brand new they are a good brand but can't mind name. He is ni-coilovers.com or co.uk. Hope this helps
The only way forward is sideways
Zippy2012
  • Worcester uk
« Reply #2 on: 19 January 2012, 20:28:52 »
Cheers found them on facebook awaiting reply.... but still need 2 source the airbag issue in stiffening the rear with s,l pump...
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #3 on: 19 January 2012, 21:34:26 »
i bought my car it was fitted with monroe shocks on rear,its mv6 3.2,will sea if i can spot part no.
Zippy2012
  • Worcester uk
« Reply #4 on: 19 January 2012, 21:52:33 »
Cheers ive got a set of monroe air levelling shocks boxed ready to send back because they kept bottoming out, but speaking to monroe already there kits will only fit a car at standard right height...?? as i think my car must be way lower than a standard MV6 as on a flat road if i boot it it drops to bumpstops! & any slight bumps in road knock like hell as shocks bottom out,
is your car empty?/ish could you measure from center of alloy to arch for me front/rear.... i have an idea of how low it really is compaired to a standard car... Cheers M8
