LSD Diff and Calibrated Speedo Clocks.
Started by zirk, 22 January 2012, 00:59:56
zirk
For Sale ex plod LSD Diff (100k miles) with calibrated Speedo clocks (155 Mph), all known to be working as normal, please check before buying, Believed to be 3.9 ratio, 2.55 rpm at 70 mph in top with standard 16" alloys, Ar35 box, I can recalculate the mileage to suit your car, but I will not be party to mileage fraud, proof is needed if ness.
£225.00 inc delivery UK, NI and IR only. (slow Snail)
Thanks Chris.
sjc
I'm interested.  What year are clocks from?  i.e. F/L or M/F/L
How much just for the LSD?
zirk
Good point, from a Facelift, Im sort of throwing the Clocks in with it, so as to keep the Speedo accurate in case the buyer has different diff ratio.
sjc
Quote from: zirk on 22 January 2012, 12:08:05
Is it the diff on its own, or with driveshafts?
Just for info... speedo reading is taken from the ABS sensor on the front n/s wheel mate, so no need to change the clocks but it's great that you're throwing them in.
zirk
Quote from: sjc on 22 January 2012, 12:16:40
Correct, so why am I thinking changing diff ratio will upset the speedo?
Let me think about the driveshafts, postage etc, will pm you.
Driveshafts across the V6 range are all the same irrespective of LSD or not :y
zirk
Thanks Rob, just had it stuck in mine brain, change diff ratio equals speedo wrong, too use to the old way of doing things, you know moving cables and spinning magnets, etc.  :D
Old habits die hard. :-X
sjc
Quote from: RobG on 22 January 2012, 14:16:31
I suspected as much, thanks for confirming.  What I was thinking though was, no driveshafts would mean no LSD oil and potential difficulty getting other shafts to seal properly - I was being stupid really though, cos at 100k, it'd make sense to change the oil and put new seals on anyway!
Zirk mate, don't bother getting a price for shipping with driveshafts, I have 3 pairs here anyway.
Now I need to see if I can get the money together  :-[ so feel free to sell to someone else.
zirk
Thanks for the heads up sjc, its provisionaly sold  / onhold 'ish, just awaiting confirmation over the day or two.
Probabaly going to have another one coming up in a month or so.
Thanks Chris.  :y
zirk
Sorted, no longer for sale, thanks for the interest.
Admins, Mods can lock if you wish.
Chris.  :y
