Author Topic: Dead Climate Control Display  (Read 7334 times)
Joiner
  • Leighton Buzzard, Bedfordshire
    • Omega 2.6 V6
Re: Dead Climate Control Display
« Reply #15 on: 24 January 2012, 13:43:42 »
First off, just went and tried to turn this display on with the ignition on and no joy, nothing at all.
Webby, mine is the CCR 2006 as shown in the first post. Ive also taken a tape and measured the hole centres and they are around 85mm ctrs if that helps.
« Reply #16 on: 24 January 2012, 13:47:48 »
I tried everything to get mine out including Allen keys  ::) but wouldn't come out.
Have a go but if it won't come out I note you're in Bedford... I'm in Northampton if you want to pop to my work I'll get the stereo out for you!  :y PM me if you want to ;)
I'll give a try Webby but if it comes to it I might just take you up on your offer :y
Without trying to state the obvious, have you checked it's actually switched on by pressing the top left or top right rotary knobs? ;)
I think I have but I'm going to check to make sure :-[
No probs. I'll take them to work with me tomorrow and I get OOF access at work so just PM tomorrow if you want to come up. If not no worries ;)
Might just be worth checking mine will work on yours though first....
I have the two ''double prong'' removers to remove my ''2005''. Are these the right ones for your stereo?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 24 January 2012, 13:48:27 »
Ok.
Can someone confirm these will fit in Joiners' holes?  :D :D :D
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #18 on: 24 January 2012, 13:49:16 »
Sorry Rob. Couldn't type fast enough  ::)
Then as said Joiner, just PM me tomorrow if you need to pop up  :y
RIP Paul Lovejoy
Joiner
    • Omega 2.6 V6
« Reply #19 on: 24 January 2012, 13:49:47 »
Ok.
Ooooohhhh Matron :-X
« Reply #20 on: 24 January 2012, 13:53:38 »
and make sure you have the radio code.
Does everything else work ???
« Last Edit: 24 January 2012, 13:56:27 by RobG »
Webby the Bear
  • Northampton
« Reply #21 on: 24 January 2012, 16:28:17 »
I didn't have to input my radio code again. But it says on the guide to have it so best do just in case ;)
RIP Paul Lovejoy
« Reply #22 on: 24 January 2012, 16:36:57 »
Been "disabled" then :)
Webby the Bear
  • Northampton
« Reply #23 on: 24 January 2012, 16:41:35 »
You mean the security code has been disabled?
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #24 on: 25 January 2012, 09:55:51 »
Joiner, I have bought my tool in to work  :D :D
If you do want to come up just PM me and I can help you do it ;) If not no worries ;)
I am lunching at 1pm so if you do come up could it be 1?
Cheers
RIP Paul Lovejoy
« Reply #25 on: 25 January 2012, 10:03:56 »
Yep
