Author Topic: Dead Climate Control Display  (Read 7319 times)
Joiner
  • Leighton Buzzard, Bedfordshire
    • Omega 2.6 V6
« on: 22 January 2012, 19:18:50 »
Ever since I first bought my Omega the climate control display has not worked at all. The display I am talking about is the long horizontal one that runs along the top of the CD player console like the one in the picture below.
As you know without it you cant tell what the climate control/fans are up to.
I have checked for a failed fuse but there is nothing showing as blown. This being the case does anyone have any ideas as to what to check next. I only ask because I dont want to cannibalise the dashboard getting to it wiring if I dont have to.
Cheers, Chris
tidla
  • solihull
Re: Dead Climate Control Display
« Reply #1 on: 22 January 2012, 19:43:32 »
have not seen any posts myself regarding this problem. from a general electrics point of view, any fuses you have found to be slightly related to your problem, replace them and not just inspect them would be my first port of call.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 22 January 2012, 20:24:11 »
check boths plugs are firmly in there respective sockets at the rear of the climate panel, whilst it is out you can then check all lamps are working  :y
be abit strange for all of them to go though  :-\
this will help http://www.omegaowners.com/forum/index.php?topic=90507.0
« Last Edit: 22 January 2012, 20:27:03 by fiend61 »
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 24 January 2012, 11:13:10 »
Joiner, as Fiend suggests I'd get that panel out and make sure all is plugged in. I't's a very simple job to do.
The only minor challenge I came up against was....
When I tried to put back the metal stereo bracket (pic 2) (it easily bends to remove) I couldn't get my stereo back in afterwards. But that was me being retarded. When you pop it back in make sure it's back to it's original square shape and the stereo will slide in no problem. ;)
You'll also need stereo removal keys (£2 iirc from e-gay)
RIP Paul Lovejoy
Joiner
    • Omega 2.6 V6
« Reply #4 on: 24 January 2012, 12:03:05 »
Thanks everyone for your suggestions, particularly Fiend for pointing out that useful guide; saved me from 'mullering' my centre console at the very least :y
Anyway, couple of points, is there a substitute for the 2 DIN removal tool such as coat hanger wire/ TIG rods or anything as I would like to have a go at it tomorrow as I have an unplanned day off. If not then I'll order some from Ebay and do it another time.
The other point was, would it be possible to take out what I need to to get the displays connectors then jiggle them about with the ignition on to see if it flickers or comes back on proper?
twiglet
  • Norwich, Norfolk
« Reply #5 on: 24 January 2012, 12:12:57 »
IME experience, you really do need the proper tools to get these double-din head units out without damaging anything.  I've had CCR2006's in the past that have been an incredibly tight fit!!  :o
Preferably you'd want a decent set too, as the cheap ebay ones don't tend to be made very accurately.  If however, they are all you can get hold of, you can file them down to create a better shape as per the guide.
Whatever you do, do not pull on the head unit fascia panel, as you will definately break it!!  :y
« Reply #6 on: 24 January 2012, 12:29:04 »
Pulled out quite a few with "cheapo" tools (2006`s & 2013`s). Come out easy enough with no damage :y It`s the way you pull `em ;)
Joiner
    • Omega 2.6 V6
« Reply #7 on: 24 January 2012, 12:38:09 »
Would a ratchet strap tied to the rear head rests do the trick? :y ;D
Webby the Bear
  • Northampton
« Reply #8 on: 24 January 2012, 12:55:29 »
I tried everything to get mine out including Allen keys  ::) but wouldn't come out.
Have a go but if it won't come out I note you're in Bedford... I'm in Northampton if you want to pop to my work I'll get the stereo out for you!  :y PM me if you want to ;)
RIP Paul Lovejoy
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #9 on: 24 January 2012, 12:57:36 »
Without trying to state the obvious, have you checked it's actually switched on by pressing the top left or top right rotary knobs? ;)
Joiner
    • Omega 2.6 V6
« Reply #10 on: 24 January 2012, 13:18:53 »
I'll give a try Webby but if it comes to it I might just take you up on your offer :y
I think I have but I'm going to check to make sure :-[
twiglet
  • Norwich, Norfolk
« Reply #11 on: 24 January 2012, 13:22:56 »
If it's turned off, it should say 'OFF' on the display.  :y
twiglet
  • Norwich, Norfolk
« Reply #12 on: 24 January 2012, 13:24:09 »
Rob's picking on me today!  :'(  I agree there's definately a nack to pulling them out Rob, but you have much more experience than the OP.  Better to be safe than sorry.  :y
Joiner
    • Omega 2.6 V6
« Reply #13 on: 24 January 2012, 13:25:47 »
Answers that then because it doesnt, dead as a door nail it is!
Webby the Bear
  • Northampton
« Reply #14 on: 24 January 2012, 13:28:21 »
No probs. I'll take them to work with me tomorrow and I get OOF access at work so just PM tomorrow if you want to come up. If not no worries ;)
Might just be worth checking mine will work on yours though first....
I have the two ''double prong'' removers to remove my ''2005''. Are these the right ones for your stereo?
RIP Paul Lovejoy
