Author Topic: Ticking noise from cam cover area  (Read 1111 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« on: 23 January 2012, 16:01:08 »
Changed the cam covers as oil was in the plug wells the other week.
I have a ticking noise coming from that area  :( Not sure if it has started after the covers were changed  :(
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: Ticking noise from cam cover area
« Reply #1 on: 23 January 2012, 18:21:31 »
could be a warped exhaust manifold?
Omega_Dan
« Reply #2 on: 23 January 2012, 18:26:48 »
If it goes away when car the gets warm then sounds like exhaust manifold gaskets.
SJKOO01
« Reply #3 on: 23 January 2012, 18:38:20 »
Or could be something simple like the exhaust manifold heat shield tapping away on the manifold itself if a fixing has snapped / broken off.
Broken heat shield or cracked manifold can give the impression of the cam followers chatting away.
SteveAvfc.
    • Mv6 2.6 V6
« Reply #4 on: 23 January 2012, 18:39:23 »
Check manifold in case it,s cracked, or like what i have and that is a stud missing from the manifold its self. Noise disappears once warm so i just put up with it.
Omega 37
  • Northampton
« Reply #5 on: 23 January 2012, 18:51:57 »
Does not go away when the engine is hot  :(
Will have a look at the manifold  :y
