Author Topic: engine problem  (Read 3345 times)
farmboy
  • Devon Cornwall border
    • Omega 2.5 Diesel
engine problem
« on: 25 January 2012, 20:53:02 »
Hello, I'm having a prolem with the engine on my 1998 omega 2.5 turbo diesel. it will start when I turn the key but stops when I release it! Is this a crank sensor problem, can I test it? would be glad of any help. farmboy.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: engine problem
« Reply #1 on: 25 January 2012, 21:01:26 »
sounds more like ignition lock fault if when you stop starter, it stops.
does the ignition light go out when it does this?
« Last Edit: 25 January 2012, 21:03:37 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
Re: engine problem
« Reply #2 on: 25 January 2012, 21:08:35 »
IME of crank sensor issues, it was starting the engine where I had the problem, once the engine was running there was no problem...
freecall666
Re: engine problem
« Reply #3 on: 25 January 2012, 21:28:13 »
or it could be a bad earth, check earths in engine bay make sure they are clean and tight.
Re: engine problem
« Reply #4 on: 25 January 2012, 22:24:49 »
Try doing the paper clip test and post up any codes you get
farmboy
    • Omega 2.5 Diesel
Re: engine problem
« Reply #5 on: 26 January 2012, 14:01:41 »
Hello, sorry I dont know how to do the paper clip test. Can you tell me? thanks farmboy.
farmboy
    • Omega 2.5 Diesel
Re: engine problem
« Reply #7 on: 26 January 2012, 14:33:53 »
Hello Ihave just checked the earth, which are fine, but does not start at all now just a lot of smoke/fumes? thanks, farmboy
freecall666
Re: engine problem
« Reply #8 on: 26 January 2012, 17:51:50 »
had a tractor that did that had to much fuel getting in on start.. old mas freg. if remember fuel timing was out.
Re: engine problem
« Reply #9 on: 26 January 2012, 17:53:31 »
Check for codes first.
freecall666
Re: engine problem
« Reply #10 on: 27 January 2012, 00:58:51 »
also if you have one of them hand pump primers on they can leak and you not get the right amount of pressure in the line to start.
hoofing it
Re: engine problem
« Reply #11 on: 27 January 2012, 08:04:41 »
As he says check codes first and post results.
Mind the codes starts of with a test code 12 one flash followed by 2 flashes of the eml light.it repeats this three times and is the same for any other code after the test code :y
How much fuel is in the tank.
« Last Edit: 27 January 2012, 08:07:36 by hoofing it »
farmboy
    • Omega 2.5 Diesel
Re: engine problem
« Reply #12 on: 27 January 2012, 09:53:51 »
Hello, I did the fault test with the paper clip and code 49 was the only one that came up can some one explain what this means. and there is above 20 litres in the tank. thank you all farmboy.
Re: engine problem
« Reply #13 on: 27 January 2012, 11:58:02 »
When were the glow plugs last changed. Try letting the glow plugs heat up a few times to see if that helps.
hoofing it
Re: engine problem
« Reply #14 on: 27 January 2012, 14:39:46 »
What colour is the smoke.
Also check the injector leak off pipes for drawing air and also make sure the fuel filter is seated properly
