f/s 2001 51 2.6 auto cdx saloon....gauging interest
Started by ngrainqey, 29 January 2012, 10:49:13
ngrainqey
hello, im trying to gauge interest as i really want a manual facelift 3.0/3.2 , i've been offered a 3.2 facelift estate which im quite tempted by just that i dont really need an estate if im being honest, its just me and occasionally airport run luggage/ engine hoists and gearboxes which go in the saloon anyway.
this is the car in question: http://www.omegaowners.com/forum/index.php?topic=95435.0
good bits:
i've fitted an ar35, new gm crank sensor, new wishbones(ok i havn't got round to fitting passenger side yet but if its going then i can if somebody wants) its done less than 200 miles since so still fresh incase somebody wanted to use them on another car and same for crank sensor
replaced window switch so all those work
buyer can have the old ar25 and t/c
bad bits:
front bumper needs spraying, i tried spraying it after filing some knocks etc and the colour match wasnt very good
managed to crack the windscreen with the cold weather which i can have done for £75 but depends if someone wants or if they just want it for bits
rust on rear arch as previous thread and odd small bubble appearing on rear doors
diff noisey but have sourced a replacement so can be with it fitted or not fitted if you just want the diff to flog
bit of a knock on drivers side over bumps-possibly steering box needs adjusting or droplinks if your lucky and a slightly warped front passenger side disc for what its worth lol
seat heaters still dont work, they dont bother me as id rather not feel like ive wet myself lol
it has served me quite well while ive had it but sometimes goes into limp mode with gearbox possibly solenoid being the problem
is very capable of doing long journeys without problem- did sheffield to leicester and back last night with a gearbox, diveshafts and hubs in boot quite happily lol
i'm looking at £500 but would prefer 550 as it owes me atleast that and will have 6 months tax if somebody wants it to use
thanks
alex
V8!!!!
ngrainqey
if nobody wants it for spares then i'll end up breaking it when i get another car
thanks
alex
V8!!!!
if you do break it, first Dibs on all its lifters (assuming its known silent running engine?)
ngrainqey
i'll let you know tunnie, somebody wants it whole
alex
V8!!!!
ngrainqey
V8!!!!
