Author Topic: Tech2 work by post (simple stuff only)  (Read 2100 times)
« on: 22 March 2008, 18:13:40 »
With a most of you living too far away to be able to visit Marks_DTM or I, I'm looking at doing some of the simple stuff by post by making up small rigs.  Some stuff won't be possible for technical reasons.
What sort of thing would members need programming via this method?
Dazzler
  • Haverhill, Suffolk
Re: Tech2 work by post (simple stuff only)
« Reply #1 on: 22 March 2008, 18:16:00 »
What CAN be done via this method????
Gearbox
Climate????
Give us a clue Jaime :)
« Reply #2 on: 22 March 2008, 18:22:36 »
Gearbox
Climate????
Gearbox should be a possibility if I can get a bit of post 98 loom, and ideally an ecu to test with.  Prefacelift climate, not sure, would have to test that one (could be done, but may have to have everything else in place else it may store a bucket load of codes).  Not sure about facelift, never looked at the ECU.
MIDs is an obvious one, though only pre 98 ones ever seem to fail.  Ideally need a short bit of loom to black plug to test fully, but already have that capability.
markey mark
  • SLady bitshorpe north lincs
« Reply #3 on: 22 March 2008, 18:28:43 »
Gearbox
Climate????
 i can sort you auto box loom from s regd if thats anygood jaime have a ecu too bud !! :y
« Reply #4 on: 22 March 2008, 18:30:17 »
Gearbox
Climate????
That would be ideal - PM me costs :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #5 on: 22 March 2008, 19:29:09 »
What about simple diagnostics, download onto laptop via a rig and then send via email?
« Reply #6 on: 22 March 2008, 19:32:11 »
Excellent idea :y but flawed  :'( - That would require evryone to have a Tech2
« Reply #7 on: 22 March 2008, 19:38:37 »
Hmm. Could relay the physical interface of the tech 2 over the internet to a cheapo tech 2 at the car. Depends how fussy the tech2 is about timing. :-/
Gaffers
« Reply #8 on: 22 March 2008, 19:39:32 »
Is there no way of rigging up something to read the raw data to then send on to be analysed by the Tech2?
Just thinking outside the box (no pun intended)
« Reply #9 on: 22 March 2008, 19:49:37 »
The Tech2 does the raw read, it can also do some analysis, but using TIS to view the data is often easier...
Gaffers
« Reply #10 on: 22 March 2008, 19:52:09 »
I stand corrected..... thats a bit naff really, if I were God I would make all cars able to speak and say what is wrong..  ::) ::)
« Reply #11 on: 22 March 2008, 19:55:54 »
In you case, it nearly can via a paperclip ;)
« Reply #12 on: 22 March 2008, 19:58:26 »
A bit like the Maestro Vanden Plas?  8-)
Mate of mine had one of them. Unless he belted the dashboard with a windscreen scraper it kept harping on about being low on fuel. On one occasion, just as he was pulling out of a petrol station. Then it started moaning about the brakes requiring attention, so he ignored it, of course - until the brakes failed. :o
 ;D
Gaffers
« Reply #13 on: 22 March 2008, 20:00:24 »
 ;D
Oooops  :o :o :o
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
markey mark
« Reply #14 on: 23 March 2008, 19:35:06 »
pm me your address jaime carnt seem to get your deatails up to pm you !! :y
