Author Topic: HELP OIL LEAK  (Read 1178 times)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
HELP OIL LEAK
« on: 30 January 2012, 19:27:28 »
Hi all OOF People
got major problems loosing lots of oil like I topped it up two weeks ago and multi dash said "check oil level" which is worrying me when I changed the plugs the other week oil was in the plugs and leads also smoke/steam was coming from drivers side under bonnet also it's leaking oil above the gearbox and moving down the sump it's so bad I left a puddle on my mates drive.
Now is this the rocker cover gaskets or is it something more serious I have read
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
I also want to know prices of genuine parts I'm going to have to do this ASAP also is there another guides
If I do the gaskets do I have to remove the top part of the Cambelt or does this not need to be removed
Also estimated time of changing them and special requirements
Thanks
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: HELP OIL LEAK
« Reply #1 on: 30 January 2012, 20:07:36 »
yes
no
depends how handy you are with a spanner, couple of hours shpould do it following guide on here, only use genuine vx gaskets and vx black sealant, also clean out your breathers it is these blocking up that causes the gaskets to go  :y
also if you leave it to long the oil will fry the ht leads followed by dispack  :(
afaik approx £20 a side but someone with more knowledge will give you more info on prices  :y
« Last Edit: 30 January 2012, 20:12:45 by fiend61 »
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: HELP OIL LEAK
« Reply #2 on: 31 January 2012, 00:16:15 »
PM Andyc on here, with your vehicle detail, and he should be able to give you a trade price on all the parts you need!  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: HELP OIL LEAK
« Reply #3 on: 31 January 2012, 11:12:14 »
CC Gasket is sold in the OOF sHOP. Not sure on stock. Would be interested to know if that's at TC Price?  :-\
RIP Paul Lovejoy
