Author Topic: Crank sensor and oil in plug bores.  (Read 1893 times)
AndysCD
  • Halifax UK
    • VAUXHALL omega CD
« on: 31 January 2012, 13:05:24 »
HI
just had a few jobs to do on my 2.0 Omega, 1 of them was the crank sensor....Following Haynes method sounds like a major job. So i cut down an old 8mm spanner and used the ring end to loosen the torx nut...was a decent enough fit to slacken it. Removed the dipstick tube first and created just enough room to get in. In all took bout 1/2 hour to do.
The other job was cleaning out old engine oil from plug bores, rocker gasket was totally goosed. replaced with OE part, new plugs and changed leads as they were soaked in oil and had gone quite brittle!...Runs a hell of a lot better now.
Andy
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Crank sensor and oil in plug bores.
« Reply #1 on: 31 January 2012, 13:17:10 »
Nice work, well done. Always good when you can 'feel' the difference too  :y
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #2 on: 31 January 2012, 15:16:27 »
Your profile appears to say 2.0 CD Elite. There's no such car, CD and Elite are different specs and the Elite didn't come in 2.0 litre form
TC and BnQ Trade holder.
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #3 on: 31 January 2012, 16:55:18 »
Good to hear that matey! And as to above post maybe it was a cd spec originally but upgraded a few bits  :y :y buts yes elite models didnt come in 2.0l 4pot!!
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #4 on: 31 January 2012, 17:09:57 »
why  :-\ :-\ :-\  didnt have to cut mine down to get to it ???
geoffr70
  • Sunderland
  • Boobies
« Reply #5 on: 31 January 2012, 20:30:22 »
Wouldn't be a cd elite then
« Reply #6 on: 31 January 2012, 20:40:15 »
Wishful thinking maybe or looking for 2 more pots   ???  :)  ;)
geoffr70
  • Sunderland
  • Boobies
« Reply #7 on: 31 January 2012, 22:02:32 »
AndysCD
  • Halifax UK
    • VAUXHALL omega CD
« Reply #8 on: 31 January 2012, 22:09:40 »
new to the Omega, seems a replacement drivers door was fitted at some point and has Elite on the trim. Didnt realize the different models etc. Its defo a 2.0 cd. Certainly pulls my caravan better than the last motor. Rover 620...
Andy
Stallion
  • Romford
« Reply #9 on: 01 February 2012, 04:30:48 »
Andy
 :( :(   ;D ;D
Page created in 0.017 seconds with 14 queries.
