Author Topic: Running rough  (Read 4216 times)
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
Running rough
« on: 01 February 2012, 17:27:24 »
Hi
Car cut out and the 30 amp fuse under th bonnet blew
It restarted and is now running very rough and EML is on
Codes 48 and 81 are now showing
Is this likely to be coil pack as I am thinking?
Stu
Take a look at my Dog Training blog at Dog Training HQ
Re: Running rough
« Reply #1 on: 01 February 2012, 17:48:48 »
Hi
Stu
Don`t know what engine you`ve got, but check wiring to #1 injector
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #2 on: 01 February 2012, 18:13:16 »
Apologies, thought it was still on profile pic
The car is a 2.5V6, 1999
I originally thought it may be the kickdown switch as this caused the 30 amp fuse to blow a number of years ago. I took apart switch and cleaned it the same as last time and car was fine for one day.
When it first happened yesterday, the car would not restart when I replaced the fuse, it just kept blowing the fuse. However, when I removed accelerator cable and kickdown switch, the car ran fine so I assumed that was the problem.
I have now disconnected the kickdown switch but problem is still there
Re: Running rough
« Reply #3 on: 01 February 2012, 20:08:15 »
I'm with RobG, I'd be checking the wiring around injectors and in cable tray for damage.
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #4 on: 02 February 2012, 08:15:08 »
Okay thanks both
Will let you know how I get on
Stu
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #5 on: 02 February 2012, 18:34:24 »
I have checked the wiring around injectors and in the cable tray, and all seems ok
Would a problem with the wiring possibly cause the 30 amp (under-bonnet) fuse to blow?
I cannot find any list of things that this fuse protects
Also, there was a small amount of smoke coming from back of engine when I started it today (Coming from roughly central, right at back of engine)
Any more ideas anyone?
Thanks in advance
Re: Running rough
« Reply #6 on: 02 February 2012, 18:48:56 »
Which fuse
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #7 on: 02 February 2012, 18:57:40 »
Its the 30 amp fuse in the smaller box (not shown) next to that one in the pic
Re: Running rough
« Reply #8 on: 02 February 2012, 19:03:15 »
Protects the Motronic ECU
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #9 on: 02 February 2012, 20:51:13 »
Ok thanks.
Also the car runs on lpg and the indicator in the car is no longer working
Does this mean its a problem with the ecu?
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #10 on: 05 February 2012, 15:06:10 »
I think I have located the problem.
I have had a better chance to look at it today and have stripped off the plenum to give access to the wiring.
The plastic coating has melted on some of it, so that would obviously cause the shorting out and blowing of the fuse
Does anyone have any suggestions as to the best way to repair this wiring?
There are about 6 wires in total, which lead to the 2 front left injectors (looking from front of car)
I realise that I may need to replace the injector loom in the future. But is there a way I can temporarily repair it for now?
Thanks
Re: Running rough
« Reply #11 on: 05 February 2012, 15:18:21 »
Thanks
You could try insulation tape, if that fails I`ve got the V6 loom from where it connects to the plug at the bulkhead to all injectors
« Last Edit: 05 February 2012, 15:27:19 by RobG »
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #12 on: 05 February 2012, 15:28:09 »
It doesn't look too bad to be honest.
Do you think it is likely that the wiring has worn through causing it to short out and blow the fuse? Or could something else have caused the problem and it may just happen again once I've repaired the wiring?
Sorry for all the questions, just hoping that all will be okay once wiring is repaired/replaced
Re: Running rough
« Reply #13 on: 05 February 2012, 15:33:13 »
It`s quite possible as the fault code raised did indicate an electrical problem with one of the injectors
stuvaux
    • Dog Training HQ
Re: Running rough
« Reply #14 on: 05 February 2012, 15:48:04 »
Great thanks Rob
I will let you know how it goes (maybe tomorrow now as I can only work until dark)
Will let you know if I need the injector loom you have too
Thanks
Page created in 0.135 seconds with 16 queries.
