Author Topic: complete coolent flush  (Read 3097 times)
Latchie_3.0v6
  • OMAGH N.IRELAND
    • Omega 3.0 v6 elite (sold)
« on: 01 February 2012, 19:51:26 »
i was thinkng about doing a complete coolent flush on my car.
how do i go about doing this on an omega. done it on my womens 206 with no problems but was wondering if it was the same for all cars.
NOTE i want to do it properly.
The only way forward is sideways
Latchie_3.0v6
  • OMAGH N.IRELAND
Re: complete coolent flush
« Reply #1 on: 01 February 2012, 19:58:51 »
ok found how to do it in maintence guide.
just one more Q wot is burping the system
« Reply #2 on: 01 February 2012, 20:04:19 »
bledding the air out by repeated squeezing top rad hose...
Latchie_3.0v6
  • OMAGH N.IRELAND
« Reply #3 on: 01 February 2012, 20:14:24 »
sorry to ask but where bouts is that
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #4 on: 01 February 2012, 20:17:48 »
You'll know when you squeeze it as you'll see air bubbles being forced up out the coolant but it's a biggish pipe that runs by the side of the header tank  :y
RIP Paul Lovejoy
« Reply #5 on: 01 February 2012, 20:17:58 »
at the top of the radiator  ::) ::) ::)
I'd also be squeezing the bottom radiator hose ........... found at the bottom of the rad.  ;) ;) ::)
« Reply #6 on: 01 February 2012, 20:19:20 »
top rad hose is t'other side of the engine from the header tank .......... top hose is virtually next the battery.  ;)
Webby the Bear
  • Northampton
« Reply #7 on: 01 February 2012, 20:19:26 »
I also note on the diesel there is a drain directly from the block i would imagine. a lot easier than my v6 (and anyone else with a v6) as you can only get 50% of coolant out at a time, hence having to flush it
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #8 on: 01 February 2012, 20:20:19 »
oh. lol. well which one was i squeezing then? i assumed i'd got the right one as i was forcing air thru it lol
RIP Paul Lovejoy
« Reply #9 on: 01 February 2012, 20:20:59 »
but the rad tap is easy to get at though.  :y :y
Webby the Bear
  • Northampton
« Reply #10 on: 01 February 2012, 20:22:38 »
very true ;)
RIP Paul Lovejoy
« Reply #11 on: 01 February 2012, 20:25:06 »
TD having a block drain (like your beloved senator iirc) and a rad drain makes it easier to completely renewal coolant :). Not that its hard on a v6, just more time consuming...
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #12 on: 01 February 2012, 20:27:57 »
I thought the cooling system was self bleeding
never done this on my car and with no problems.
Webby the Bear
  • Northampton
« Reply #13 on: 01 February 2012, 20:29:14 »
not much to do is there... most of the time is spent drinking tea while coolant comes out  ;D ;D
RIP Paul Lovejoy
« Reply #14 on: 01 February 2012, 20:37:37 »
It usually is. Occasionally you do get a lock though...
