Author Topic: What do you think ?  (Read 2847 times)
What do you think ?
« on: 06 February 2012, 10:31:00 »
2 hrs taking the diss pack out and this is how it looks .....
Not good , so im guessing this is the problem that was causing my bad running  :-\
« Last Edit: 06 February 2012, 10:32:54 by eatmydust »
Re: What do you think ?
« Reply #1 on: 06 February 2012, 10:32:50 »
In the bin
« Reply #2 on: 06 February 2012, 10:35:20 »
Makes sense to the running and no power to number 1 HT as thie rusty bit is where the number 1 HT went into .
« Reply #3 on: 06 February 2012, 10:35:36 »
Door stop ;)
« Reply #4 on: 06 February 2012, 10:36:28 »
You'll have two cylinders down  ;)
« Reply #5 on: 06 February 2012, 10:39:06 »
Pig to get the bolts out BUT its out thank god .
« Reply #6 on: 06 February 2012, 10:40:27 »
1 and 4 think , thought it sounded rough  ::)
« Reply #7 on: 06 February 2012, 10:40:46 »
When replacing them try a long 8mm socket instead of the torx socket ;)
twiglet
  • Norwich, Norfolk
« Reply #8 on: 06 February 2012, 10:42:56 »
Seen worse for sale on the bay!  ::) :-X
« Reply #9 on: 06 February 2012, 10:43:44 »
I used an 8mm socket pete , the awkward one closest to the engine block in the corner i used 2 small extensions and a knuckle joint while i was kneeling on top of the engine  :D
« Reply #10 on: 06 February 2012, 10:55:28 »
I remove the plenum and inlet manifold, its nice and easy then :y
2woody
  • Northumberland
« Reply #11 on: 06 February 2012, 11:36:01 »
that's a FAIL.
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #12 on: 06 February 2012, 12:27:47 »
Bung a bit of Blutak in there that will be alright dont know what your worried about :D
« Reply #13 on: 06 February 2012, 13:27:24 »
Plenum not removed , i have discovered i have fingers that bend in all directions  :-\
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #14 on: 06 February 2012, 15:20:08 »
Hey !   I've got one of them.....Sits on my desk at work....Makes for a VERY good paper weight.
