Author Topic: CID and NCDC from another car  (Read 3122 times)
omegafin
  • xxx
« on: 07 February 2012, 14:14:00 »
if I take both CID and NCDC radio from same car and install them to another car they will work without Tech programming,
But if I want later unpair them can it be done if I know donor car's security code , or must car's and radios sec code be same  before I can unpair them ??
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CID and NCDC from another car
« Reply #1 on: 07 February 2012, 14:16:18 »
To save any future problems, (and there will be some trust me,)
Depair correctly from the donor car with Tech2 before transplanting into new car.
Radio & Decoding Technician
www.dndservices.co.uk
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 07 February 2012, 14:16:25 »
Yes and Yes.
« Reply #3 on: 07 February 2012, 18:38:23 »
Yes, as long as no telematics involved. Additionally, the configurations need to be the same - Bose, wheel size, engine, gearbox, headlights etc etc.
omegafin
  • xxx
« Reply #4 on: 07 February 2012, 19:09:29 »
Donor car is not driveable anymore so it can't be depaired , so can depairing be done in another car if pairing code is known ???
    • 530D M Sport, 330i Coupe
« Reply #5 on: 07 February 2012, 19:11:00 »
Yes
zirk
  • Epping Forest
« Reply #6 on: 07 February 2012, 19:18:17 »
Whats the issue with Telematics TB, ie If I took out  paired 2015, CID and Telematics with known code and replaced with 2013 and paired CID also with known code?
« Reply #7 on: 07 February 2012, 19:21:04 »
Think TB means if you move Telematics, CID/GID, NCDC to another vehicle you will need to build yourself a Telematics Sub loom.
« Reply #8 on: 07 February 2012, 19:26:37 »
Yes, if all parts of the system are complete (NCDxxxxx, the CDC3, the display, and the telematics)
zirk
  • Epping Forest
« Reply #9 on: 07 February 2012, 19:29:24 »
Ah ok, yea thats ok was starting to think theres other issues.
Chris
« Last Edit: 07 February 2012, 19:32:24 by zirk »
« Reply #10 on: 07 February 2012, 19:47:43 »
Complications with telematics is that telematics must be kept with its associated parts, and the loom changes needed (either to fit or to remove (and replace with bluetooth kit))
