Author Topic: omega 2.2dti 2003 estae alarm goes off on its on  (Read 2187 times)
mikey 67
    • omega 2.2dti cdx 2003 est
« on: 07 February 2012, 17:21:43 »
 :-\hi  can any 1 help  i have an omega estate and alarm goes off on its on once set 30 minutes later it sounds and horn goes off or sounder and then starts beeping u press fob nothing u get in and it starts even when its still sounding weird also whats the bottle thing under front drivers wing panel it sounds like a fan  with  smoke from like an exhaust
thanks mike
« Last Edit: 07 February 2012, 17:23:35 by mikey 67 »
waspy
Re: omega 2.2dti 2003 estae alarm goes off on its on
« Reply #1 on: 07 February 2012, 17:59:51 »
The smoke is nothing to worry about, it's normal & it's only noticable in cold weather. There's alot of diesels do it.
As for the other problem, I'm not sure.
twiglet
  • Norwich, Norfolk
« Reply #2 on: 07 February 2012, 18:07:08 »
thanks mike
Alarm... Start by checking the bonnet switch and the connections to the break sensors in the rear side glasses.  I've heard both of them causing issues with setting the alarm off.
Under the osf wing, you have a diesel powered coolant heater.  It kicks in under 5 degrees air temp, and helps to get the coolant up to temperature quicker from cold starts.  It's basically a little 3kW boiler, and has it's own little exhaust which is where you are seeing the smoke from... totally normal.  :y
    • 530D M Sport, 330i Coupe
« Reply #3 on: 07 February 2012, 18:55:38 »
The beeping might also indicate that the powersounder is about to die.
mikey 67
« Reply #4 on: 07 February 2012, 19:01:37 »
do u have to buy a new power sounder then  would that be the reason i run out to car and the horn goes loud then dull  then  after a few seconds it beeps really loud i try to turn off the alarm the noise stops sometimes then goes again i get in turn the key and engine starts and still beeps until i take key out weird u feel like keeping your eye on car which is time consuming as neighbours say  its going off again  :-\
« Last Edit: 07 February 2012, 19:13:19 by mikey 67 »
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #5 on: 07 February 2012, 21:01:37 »
Most likely to be power sounder but here is a bit of an unusual cause of alarm triggering about 30 mins.after lock up.
Does the heated rear screen work ?
I had this problem which was proved to be due to busted heated rear screen element.  It was caused by carrying a large woody hydrangea in the back of the full car. The woody stems managed to bust every single strand of the heater element during a 14 mile journey. I did manage to disable this continuity check by changing the wiring in the front drivers foot well side panel, until the screen was replaced, but it is so long ago I have forgotten what I did!
The integrity of the rear screen is checked by the alarm system via the heater element continuity.
Check with a meter across the element connectors , or even on the actual wires on the inside of the rear screen.
best of luck
mikey 67
Re: omega 2.2dti 2003 estate alarm goes off on its on
« Reply #6 on: 07 February 2012, 21:06:59 »
thanks ill check does the power sender need replacing then if heater works or can i just take sender out does that disable alrm or immobilzer ??
thanks
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #7 on: 07 February 2012, 21:12:36 »
if power sounder is going off you only have to put ignition to position 2 then off and powersounder should stop you dont have to start car  :y  if full alarm is going off i would first check bonnet switch unplug it and see if that stops the alarm going off  ;) what can happen is that te bonnet switch is only just making contact with the bonnet and after driving and warming everything up it is making contact as it rapidly cools off in these temperatures metals contracts and you lose contacts hence the 30min period  :y   try unplugging if that cures it you can then bend bracket up slightly so its making the contact it should  :y  but dont bend until you have unplugged and tested otherwise you dont know whether it is the bonnet switch at fault or something else  :y
hope this helps you out  ;)
if power sounder is beeping i would take it out of the car can cause fires  :(, but due to insurance purposes you should really replace  :y
« Last Edit: 07 February 2012, 21:14:33 by fiend61 »
mikey 67
« Reply #8 on: 07 February 2012, 21:57:19 »
hi and thanks have unplugged bonnet sensor and it still goes off and horn sounds full on then dulls  bt then the beeping i presume is the power sounder goes off until i put key in and start car and beeping is still going with engine running then stops is power sender possible to replace i saw on here it has rechargable batteries in them can i simply unplug and replace with a new one or is it vauxhall that should do it does it require seting back up afterwards
thanks  ;)
fiend61
  • york
  • each to their own
« Reply #9 on: 07 February 2012, 23:19:17 »
powersounder should only go off if the battery is disconnected, as you say car alarm goes off then dulls wonder if your battery is nearly flat therefore making the powersounder think its disconnected  :-\  but in normal terms a beeping power sounder means that its fubared there is a howto on here that shows how to replace the batteries in it  :y also think it was andyB or robG that posted up a cheap replacement sounder  :y  if alarm still going off with bonnet switch disconnected then you will have to start delving deeper is it an estate?
edit---- yes it is an estate  :-[  the other thing to check is the rear window alarm strips just seems funny  that it is a set amount of time before the alarm triggers  :-\
sorry cant be more help unless i suddenly have a brainwave but doubtful  seeing as the whiskey bottle is out  :y
« Last Edit: 07 February 2012, 23:22:27 by fiend61 »
