Author Topic: Had One of Those Days  (Read 1493 times)
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
« on: 24 March 2008, 17:49:27 »
Took the mig to the folks house over the weekend near inverness
Took the new front & rear discs & pads, gear box oil, filters & gaskets to borrow their garage( big enough to get the mig in with about a metre either side - bliss)
I ended up assisting my dad as he tore into the brakes with gusto. rear calipers are furb'd, so the fronts got changed & the gearbox oil & filter was changed.
During the day the mig was turned round on the driveway to back it into the garage. As I nosed it into the corner of the drive to spin it round, I didn't notice the 6-8 inch high post that secures the gate open. it went into the wheel arch on full lock, when opposite lock was on, the funny noise came from this.
Oops :P
It looked shocking, but to be fair to the car, it mostly clipped back together again, with a bit of new metalwork from my dad.
I need to share the great idea my dad had for filling the gearbox oil. An old brake fluid changer was used. it has a filler bottle, with an outlet pipe & a tyre adaptor. it uses the tyre pressure to blow 1/2 a litre of oil in in a few minutes. great bit of kit.
handy hints courtesy of brs2 ;)
« Last Edit: 25 March 2008, 20:11:49 by cbs2 »
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
miggy
Re: Had One of Those Days
« Reply #1 on: 24 March 2008, 19:09:14 »
Sorry to see the miggy with a bad nose.........as long as it went together ok.
« Reply #2 on: 24 March 2008, 19:38:13 »
Seen an easibleed used to fill autobox before. Trouble is, you have to keep refilling bottle.
cbs2
  • East Kilbride
« Reply #3 on: 24 March 2008, 21:19:10 »
thats true. the bottle only held 1/2 a litre, only good thing is the speed it pumps it.
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #4 on: 24 March 2008, 22:27:01 »
I have an easibleed and have often thought that it could be modified to fill the gearbox.
With a larger container though you would need to reduce the pressure somewhat to prevent a very messy dexron explosion or use a thick walled container.
At work we use very thick walled glass containers (Winchester quarts)for storing Methanol which apparently cannot be recycled.
I can feel a project coming on to modify one for an autobox oil change when the weather improves.
Martin_1962
« Reply #5 on: 24 March 2008, 23:20:10 »
IT can be reused in some car engines!!
« Reply #6 on: 24 March 2008, 23:31:34 »
I can testify that an easibleed makes light work of filling gearboxes. Although a killaspray fits a lot more fluid in, and there were some nice ones going cheap at the local Aldi / Lidl recently.  :y
Just need to put a schrader valve in mine for the compressor so I don't even have to pump it up.
