Author Topic: HBV  (Read 2089 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
HBV
« on: 10 February 2012, 23:00:48 »
Anyone have any idea on the price of an HBV from VX Please
I appear to have a leaking one , should the valve actually be mounted to anything mine appears to be just floating about
Its a 2002 2.6 auto
Re: HBV
« Reply #1 on: 10 February 2012, 23:03:38 »
Its a 2002 2.6 auto
About £30/£5 I think .........  :-\
Yes,it should be supported on a pressed steel bracket that locates into a slot on the HBV  :y
Re: HBV
« Reply #2 on: 10 February 2012, 23:05:45 »
About £35 iirc
It's usually mounted on a metal peg bolted to the crank case breather box iirc. Or something like. There's a plastic clip involved which always breaks. ...iirc. A cable tie ?
Re: HBV
« Reply #3 on: 10 February 2012, 23:09:56 »
...........There's a plastic clip involved which always breaks. ...iirc. A cable tie ?
Kack handed bugger!! ??? ??? Mine have both been OK  ::) ::) ::)
LFF64
  • HADDENHAM BUCKS
Re: HBV
« Reply #4 on: 10 February 2012, 23:11:14 »
Thank you  :y Would this be something they would stock do you think or is it going to be special order item  most of the bits I have wanted have had to be ordered normally only a couple of days I must admit
Re: HBV
« Reply #5 on: 10 February 2012, 23:13:55 »
They're a part that if your dealer is part of a group of dealers then one of them will likely have one, so will be available the next day if not already in stock.
LFF64
  • HADDENHAM BUCKS
Re: HBV
« Reply #6 on: 10 February 2012, 23:17:56 »
Knowing my luck it will need to be ordered then  :D
Thanks for the help
Re: HBV
« Reply #7 on: 11 February 2012, 09:11:30 »
Its a 2002 2.6 auto
:o :o
Re: HBV
« Reply #8 on: 11 February 2012, 09:21:12 »
Most dealers I've had to buy stuff from say "Oh, the Starship Enterprise"! Yes sir, we always hold a few in stock ;) ;)
Re: HBV
« Reply #9 on: 11 February 2012, 10:07:54 »
LFF64's local dealer is only a same group (thus excellent service from them IMHO).
If you're desperate, I may have a 2nd hand one here. Or play silly beggers with hoses and plugs so the car runs until you get one...
Re: HBV
« Reply #10 on: 11 February 2012, 10:12:43 »
Or play with the heater settings, it may stop leaking if it's on cold only for instance.
...or in this weather you may prefer to just let it leak ;D
Agemo
  • Cleethorpes
  • Insignia
Re: HBV
« Reply #11 on: 11 February 2012, 10:56:50 »
Mine is "bodged" at the mo, will get round to fitting my new one when it warms up a bit.
This is where it should be (on a TD) but you can see the clip which should hold it.
Re: HBV
« Reply #12 on: 11 February 2012, 11:06:49 »
Nobody said I broke it. Pedantic bugger! ;D
LFF64
  • HADDENHAM BUCKS
Re: HBV
« Reply #13 on: 11 February 2012, 16:30:24 »
TB I agree they are really good in there and always helpful  :y
They had one in aswell so that was good HBV+2l antifreeze came to £45 inc VAT
New valve fitted and sat on its mounting plate now  :y I havbe also fitted the clean breather bridge (black plastic thingy)
And as i had the plenum ? off to do the HBV (so much easier with it off  ) I changed the Orings  just for my piece of mind
Also have giveb the car a good clean outside first chance I have had since I have had the car  ;)
