Author Topic: I thought Anglian Water promised....  (Read 2220 times)
« on: 11 February 2012, 12:58:50 »
....that my water meter wouldn't freeze again  >:(
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: I thought Anglian Water promised....
« Reply #1 on: 11 February 2012, 13:18:37 »
That sucks!  Time to get the candles out, thaw the pipes :y
« Reply #2 on: 11 February 2012, 13:23:05 »
Hairdryer for 20m didn't cure it. Had to leave it, currently at WIM.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #3 on: 11 February 2012, 14:02:02 »
-10degC here last night, the retards obviously weren't expecting it to be so cold. I hope you manage to sort it asap as being without water is a pita.  >:( >:( >:(
« Reply #4 on: 11 February 2012, 14:37:05 »
- 14 here last night, -17.5 in Bucks. Coldest night for several years I would imagine.Anything with water in would need to be very well insulated etc. not to freeze in those temps.
I_want_an_Omega
« Reply #5 on: 11 February 2012, 15:29:18 »
I was gobsmacked my water supply didn't freeze last night. We are having a leaky pipe fixed under insurance. It's under the garage concrete floor and they are in the process of digging up the floor to gain access and then replace the pipe on monday.
So far, two access holes have been dug to determine depth and direction of pipe - but these were left open/exposed. I shoved a couple of old quilt covers in to keep the cold out and it seems to have done the job (so far).
« Reply #6 on: 11 February 2012, 16:52:14 »
I think TB's is above ground as it enters the house.
Ours is under ground until its under the house, where it comes up though the floor, which is heated via central heating etc.
Pipes won't freeze under ground. Or we'd all be in trouble.
« Reply #7 on: 11 February 2012, 17:33:14 »
I remember you have the same problem before.. :-\
and if I remember correctly it was in the wall (cant trust my memory completely ;D ) if that was the case
I think it must be buried below ground level.. Ours is outside in the garden and never frozen but its 1 meter below ground level..
« Reply #8 on: 11 February 2012, 17:35:59 »
I think a 5-10 watt bulb can protect it.. in case you cant change location..
« Reply #9 on: 11 February 2012, 17:37:10 »
Hardly a surprise ::) ::)
I think the job that cancelled on me this morning may actually have been the Diesel lines gelling from the symptoms :o :o Can't say for certain because I wasn't there but :-\ :-\
« Reply #10 on: 11 February 2012, 21:48:27 »
Had a -18C last year, and similar the year before
This is the 3rd year running this has happened  >:(
Finally thawed it out enough to get running water, so toilet cisterns refilled (I knew I shouldn't have had a curry last night ::)), and loft tank replenished.
Just been out to put some tools back, it friggin cold again. If it freezes the meter again....  >:(
« Reply #11 on: 11 February 2012, 23:09:29 »
 ???  to cold for an island surrounded by sea and gulf stream..
« Reply #12 on: 12 February 2012, 00:34:46 »
You don't mention reporting the fault again?
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« Reply #13 on: 12 February 2012, 09:20:57 »
The Gulf is very weak nowadays and turns back much sooner...
TB I would suggest you using of heater/warmer cable some 10 watts/meter just in case ! No need to dig such deep groove and what is more absolutely no need to dig anything at all!
C20NE - X25XE
« Reply #14 on: 12 February 2012, 10:00:37 »
I never reported it last time - they contacted me once they realised, after several months, the meter had stopped spinnig ;D
Page created in 0.048 seconds with 16 queries.
