Author Topic: question on tractor lift pump  (Read 1201 times)
mathewst
  • Split, Croatia
    • v40
« on: 11 February 2012, 19:27:52 »
I saw the manual for lift pump diagnosis.
But want to know one thing, two actually
Can you submerge the lift pump in anything (like degreaser or else)  and start it?
also in the manual it is stated to make male spades and run the pump over a battery.
Does this mean to simply connect the pump to a energy source and run it shortly, or to connect it than reverse the polarity and again reverse...?
Sorry may seem like a stupif question but I need this solved rather quickly
Agemo
  • Cleethorpes
  • Insignia
Re: question on tractor lift pump
« Reply #1 on: 11 February 2012, 21:38:01 »
It's only an electric pump, so yes it will pump any liquid (although Diesel is perfect). You can connect it to an energy source & run it, then run it the other way, it's a good method of cleaning it.  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 11 February 2012, 22:50:27 »
Clean fresh diesel ;)
mathewst
  • Split, Croatia
    • v40
« Reply #3 on: 12 February 2012, 14:38:12 »
Well put more fuel today and no luck car doesnt want to start.
I've called the mechnic he+ll be around tomorrow.
Hopefully the lift pump is the issue and can be cleaned cause I'm really short on cash
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 12 February 2012, 15:11:53 »
