Author Topic: 2.2DTi omega fuel pump fault  (Read 2519 times)
mantagte
  • great yarmouth
    • omega bmw maverick
« on: 11 February 2012, 20:51:27 »
Have been offered one cheap what is needed ?
is it just change the pump or is there programing involved
thanks
« Last Edit: 11 February 2012, 20:54:58 by mantagte »
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: 2.2DTi omega fuel pump fault
« Reply #1 on: 12 February 2012, 02:33:36 »
if its the pump at fault then you can change it, would check relay first and that there is volts getting to the pump before changing.
Solar charger fitted.
If not Broke dont fix it..
« Reply #2 on: 12 February 2012, 09:53:26 »
There's no lift pump in the tank on a 2.2DTi only the injector pump which can be swapped without programming so long as you get one with the same numbers. They are expensive though.
    • 530D M Sport, 330i Coupe
« Reply #3 on: 12 February 2012, 10:06:35 »
They are expensive enough to write off the car.....
mantagte
  • great yarmouth
« Reply #4 on: 12 February 2012, 10:49:39 »
thanks may pass on this one then
