Author Topic: Help!!!!!!!!  (Read 2102 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Help!!!!!!!!
« on: 12 February 2012, 18:31:56 »
hi all
decided today to clean my throttle body etc on the 3.2  which i done nice and clean now, put everything back together and went to start car, first thing i noticed was spanner light, so went back under bonnet and rechecked everything i had done, nothing amiss i went back to to start the car position 2 spanner light on and stayed on until started engine then went out ??? done this a few times and the same thing, pedal tricked it and now have a list of codes
0110
0300
0301
0302
0306
what have i done???   the car is running fine i think even i would notice that many misfires :D
so have i done something daft ???
please help
tia
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
Re: Help!!!!!!!!
« Reply #1 on: 12 February 2012, 18:45:23 »
have you left a bit of washing up liquid in the throttle which has contaminated the spark plugs?
In reality, I've got no idea, but hopefully someone less useless than me will be along soon to help out  :y
Carpe Incendium
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: Help!!!!!!!!
« Reply #2 on: 12 February 2012, 20:25:54 »
If the light has gone out then surely these are old codes which will clear after so many clean start ups?
I'm sure someone with more intelligence will be along soon but that's my thoughts! :y
best wishes
Simon.
martin42
Re: Help!!!!!!!!
« Reply #3 on: 12 February 2012, 20:35:01 »
could always do an ecu reset by disconnecting the battery for a couple of hours,which i did on mine when it had a lot of fault codes after coil packs went
flyer 0712
Re: Help!!!!!!!!
« Reply #4 on: 12 February 2012, 20:38:31 »
My 2.2  has spanner light on when i turn the ignition on..but once engine has started goes out.....always been that way and i thought that it was normal????? :y
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Re: Help!!!!!!!!
« Reply #5 on: 12 February 2012, 20:52:01 »
Exactly the same on mine
casared
  • Tyne and Wear
    • 2002- 2.2GLS
Re: Help!!!!!!!!
« Reply #6 on: 12 February 2012, 21:46:12 »
Same light out when fires into life
Re: Help!!!!!!!!
« Reply #7 on: 12 February 2012, 22:14:41 »
I think the OP means the light is still lit when the engine is started, so warning of an electronic engine fault code. ???
Edit: Take no notice i've had a few!!!!! :-[ ;D
fiend61
  • york
  • each to their own
Re: Help!!!!!!!!
« Reply #8 on: 13 February 2012, 17:34:52 »
well i havent noticed that before(perks of being blind as a bat)  :-\  i always thought that the spanner light went out on a timed basis, oh well you live and learn, as for the codes had them cleared and so far havent come back so must have done something untoward,some carb cleaner where it shouldnt or something  :-[ but car is running sweet as and a steady tickover of 500rpm  :) so i knew there was noway 3 cylinders where misfiring even with my ears  :y
thanks
dad1uk
  • Birmingham
Re: Help!!!!!!!!
« Reply #9 on: 13 February 2012, 20:39:38 »
thanks
Great news :y :y
best wishes
Simon.
