Author Topic: Water leak  (Read 1912 times)
Murph
  • Dartford, Kent
    • 2.5 Estate
Water leak
« on: 13 February 2012, 21:49:07 »
Just when I thought I had everything ready for MOT I seem to have developed a leak somewhere, but I cant see where from.
There's a bit of steam coming from the passenger side right at the back of the engine bay and when I looked down the back I could see a thin water line running down the side of the bell housing, close to where it mates to the block.
Being a noob to this car and engine (X25XE) I can't picture which pipes run in/above that area. I will be removing the scuttle to have a good look but I was wondering if any of you more experienced peeps might have a suspect in mind.
I changed the HBV a couple of weeks ago and once that was done there was no leak anywhere.
There is plenty of ant-freeze in the system but with the temperature dropping to -10 here the other day I wont rule out a core plug or something - are there any in that area?
Oh and I broke the bonnet release cable too... what a great day!
Re: Water leak
« Reply #1 on: 13 February 2012, 22:01:12 »
Coolant transfer pipe at rear, coreplug at rear of head, coolant bridge in the "V", headgasket. IIRC the easiest way to locate the source is a pressure test with plenum removed
Agemo
  • Cleethorpes
  • Insignia
Re: Water leak
« Reply #2 on: 13 February 2012, 22:01:37 »
Sounds like the HBV to me, did you fit new or second hand?
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: Water leak
« Reply #3 on: 13 February 2012, 22:11:30 »
I fitted a new but none genuine one.
The car had a few other problems at the time so I sourced cheaper parts to start with so that the car didnt turn into a money pit.
I'm starting to like the car alot though so this trend will not continue!
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: Water leak
« Reply #4 on: 13 February 2012, 22:13:28 »
Exactly the kind of tips I need - ta!
Re: Water leak
« Reply #5 on: 13 February 2012, 22:14:18 »
Assuming you`re "non-genuine" HBV is not leaking ;)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Water leak
« Reply #6 on: 13 February 2012, 22:15:58 »
the hbv is on the other side  :y
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: Water leak
« Reply #7 on: 13 February 2012, 22:19:03 »
It is that - but just to appease the doubting thomas in us all I will check it anyway!  ::)
Re: Water leak
« Reply #8 on: 13 February 2012, 22:19:26 »
Depending where its leaking from it could still leak in the way described though,imo.
