Author Topic: PFL Estate Rear N/S Electric Window.  (Read 1479 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 14 February 2012, 17:46:44 »
Has decided it wants to just fall open of its own accord!  I'm seeing if anyone can help with probable causes?
Electric window button does nothing on either the door or the consul by the gearlever.
Any thoughts befoe i strip it down and stress myself out....  :D
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: PFL Estate Rear N/S Electric Window.
« Reply #1 on: 14 February 2012, 19:13:33 »
the wires from the piller to the door, wires may have split, should remove easy to check wires behind the rubber flex seal.
Solar charger fitted.
If not Broke dont fix it..
P6UL K
  • Dartford, Kent
« Reply #2 on: 14 February 2012, 20:33:58 »
Ok thats one issue, but why is the window just falling open downwards?  Could it have come off its runners?
freecall666
« Reply #3 on: 15 February 2012, 07:22:01 »
so its not the motor making it fall down? if the wires are cut, should not fall down unless the window has been lifted off the runner, even with a broken adjustor the window would stay in place, can get a short in wires to make motor drop window. the only other thing would be the cog on the motor coming of its shaft, but its bonded to the shaft. but would think the window was dow when the wire was cut  and some one has lifted the window and dislodged it.
P6UL K
  • Dartford, Kent
« Reply #4 on: 15 February 2012, 17:53:58 »
Found out what the problem is... Can you guess what it is?
« Reply #5 on: 15 February 2012, 18:02:40 »
Where`s the motor, can`t see any rivets :-\
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #6 on: 15 February 2012, 18:05:24 »
wtf, someone removed motor and then propped window closed with wood and thats now fell over
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
freecall666
« Reply #7 on: 15 February 2012, 18:27:58 »
well thats a new one for the book. is that setup in a manual some were? surprised it was not glued in. or some other thing holding it in place. so new motor then needed.
P6UL K
  • Dartford, Kent
« Reply #8 on: 15 February 2012, 19:36:39 »
I was as surprised as you were! Well random!  :o
