Author Topic: Wanted @ a reasonable price working CCR 2006  (Read 6775 times)
Re: Wanted @ a reasonable price working CCR 2006
« Reply #15 on: 15 February 2012, 13:50:57 »
The message on the display is what I have also taken it from, but you will need to make sure that it is the original stereo to the vehicle as a BOSE stereo will run a non-BOSE system, but not vice-versa.
Checking the rear shelf for speakers is the quick way to tell.
As Dave says, quick, simple & definitive :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #16 on: 15 February 2012, 13:54:32 »
Oops!  Estate - !!
Check for a subwoofer speaker in the rear quarter panel
Radio & Decoding Technician
www.dndservices.co.uk
twiglet
  • Norwich, Norfolk
« Reply #17 on: 15 February 2012, 14:05:01 »
As dave says, look in the boot.  On the left hand side of the boot, there is a vertical panel about the size of an A4 sheet of paper. Turn the 2 knobs a quauter turn and the panel will open and drop down...
If you see a speaker mounted in a black plastic casing, you've got a Bose system.
If you see a handy cubby hole for storing crap, you don't have Bose.
Simples.  :y
« Reply #18 on: 15 February 2012, 14:13:31 »
Looks like he might be pretty close to you too Albs  :y
Didnt notice that. If  he cant acertain for certain i may be able to have a gander.Whereabouts are you mate ? answer by PM if you want. :y
« Reply #19 on: 15 February 2012, 14:13:43 »
Simples.  :y
O/S I believe James
« Reply #20 on: 15 February 2012, 14:26:07 »
pm me your reg....I can say what your car had from the factory.....although obviously that was a long time ago and anything can have been fitted since.
JDX
  • Hersham, Surrey.
    • '02 2.2dti CDX estate.
« Reply #21 on: 15 February 2012, 14:48:14 »
Sorry for the slow response - the car is parked up the road because it won't fit on the drive (please don't!!) so Im back & forth.
I cannot find anything that suggests a Bose system is fitted & I therefore now think it is not.
Jimbob: Thank you, that is kind of you.The registration no now is .
Albs: Thank you also. I don't wish to put anyone to any trouble but if you are passing, I am in Halstead Essex.
The address is
admin edit to remove personal info.
« Last Edit: 15 February 2012, 15:14:38 by Jimbob »
JDX
  • Hersham, Surrey.
« Reply #22 on: 15 February 2012, 14:57:56 »
twiglet: Sorry, I have just spotted your message. Yes, I have looked in the cargo/boot area & cannot see a speaker in a black plastic casing so I think it is unlikely that the car is fitted with the Bose system. (Jimbob is somehow checking records to establish the original spec of the car) Ho hum! It's a little disappointing that there is no Bose sound but its not the end of the world & after all this is resolved I will be happy to simply have something to play CD's on.
« Reply #23 on: 15 February 2012, 15:04:51 »
5 minutes away then. :y Have you read your personal messages ? At the top of the page where it says "my messages".Click on it and then you will see your messages. :y
« Last Edit: 15 February 2012, 15:14:57 by Jimbob »
« Reply #24 on: 15 February 2012, 15:15:33 »
Your car didnt have bose originally...
spec list :
2AU = EXTERIOR PAINT,SEE MODEL CATALOGUE FOREWORD PAINT CHART
2J5 = COVER,FLOOR INNER S/DELUXE
80I = INTERIOR-BLACK
80X = BODY INTERIOR TRIM-BLACK
A32 = ELECTRICALLY OPERATED WINDOWS,FRONT
A33 = ELECTRICALLY OPERATED WINDOWS,REAR
AJ3 = FOR DRIVER AIR BAG
AJ4 = FOR PASSENGER AIR BAG
AM9 = REAR SEAT,SPLIT COLLAPSIBLE
AP0 = FOR SIDE AIR BAG,LH
AP1 = FOR SIDE AIR BAG,RH
AP9 = LOAD COMPARTMENT NET
AQ6 = FRONT SEAT,ADJUSTABLE BACK
AR6 = BELT,REAR SEAT,CENTER,3 POINT
AS2 = FOR FOLDING FRONT SEAT,LH
AT0 = HEAD RESTRAINT,REAR,CLOTH,FULL
AU0 = DOOR LOCK,WITH REMOTE CONTROL
AV7 = USED WITH REMOVABLE CARGO RESTRAINT
AXR = WITH VIN PLATE AREA
AY5 = HEAD RESTRAINT,REAR,CLOTH,CENTER
B75 = COVER,ASSY.,LUGGAGE
BC2 = ORNAMENTATION,WOOD
C60 = AIR CONDITIONING
C68 = FOR ELECTRONIC AIR CONDITIONING
C87 = READING LAMP,REAR
C90 = DOOR LAMP
CE4 = HEADLAMP WASHER
CF5 = SUN ROOF,TRANSPARENT,ELECTRIC
D44 = COVER,MIRROR HOUSING,O/S,PAINTED
D63 = BOX,DEPOSIT,FLOOR,FRONT
D64 = VISOR,SUN,WITH ILLUMINATED MIRROR,PASSENGER
D74 = VISOR,SUN,WITH ILLUMINATED MIRROR,DRIVER SIDE
GM3 = AXLE RATIO 3.45
K09 = ALTERNATOR,120AMP
K30 = CRUISE CONTROL
KA1 = FOR HEATED FRONT SEATS
LL9 = X22DTH TURBO-DIESEL ENGINE
M79 = MANUAL TRANSMISSION,5 SPEED
MM3 = USED WITH MANUAL TRANSMISSION
N33 = FOR TILTING STEERING COLUMN
N40 = POWER STEERING, NON-VARIABLE RATIO
NC0 = EQUIPMENT,EUROPEAN UNION
NC9 = EMISSION,DIESEL,WITH CATALYTIC CONVERTER,VARIANT 3
NP5 = STEERING WHEEL,LEATHER
PF5 = WHEEL,ROAD,ALUMINIUM,7 SPOKES,7JX16
QOA = TYRES,225/55 R 16-94V
R12
RHD = RIGHT HAND DRIVE
RUE = MANUFACTURED IN RUESSELSHEIM
T5L = LETTERING,CDX
T67 = BATTERY,70AH
T6B = TRIM PANEL,INNER,STRIPPED
T72 = HEADLAMPS,LH TRAFFIC
T96 = FRONT FOGLAMP
T97 = HEADLAMPS,XENON
U3F
U53
UA6 = ANTI-THEFT WARNING SYSTEM
UC1 = SPEEDOMETER,ASSY.,M.P.H
UF6 = LAMP,AIR VENTS
UJ3
UU7 = RADIO,CCR 2006
UV5 = MULTI-FUNCTION DISPLAY,VAT3
UW5 = SPEAKER SYSTEM 6,BASE
UY3 = TELEPHONE D-NET
VG2 = PROTECTION WAX,DELETE
W1Y = FOR STEERING WHEEL RADIO OPERATION
W4Y
W6E = TRIM,CLOTH,DELUXE
W8X = ADDITIONAL PARTS,RADIO INSTALLATION
WAD
XN8 = FOR GREAT BRITAIN
XQ2 = FOR VAUXHALL
Z1B = NOZZLE,WASHER,HEATED
Z1G = SPEEDOMETER - MILES
Z1R = ADJUSTER PASS ST SEAT,4 WAY,POWER VERT,MANUAL HORIZ.,PASSENGER
Z1Y = PAINT,TWO COAT
Copy
Paste
Delete Part
Clear List
View part history
Add Note
JDX
  • Hersham, Surrey.
« Reply #25 on: 15 February 2012, 15:26:52 »
Jimbob - thanks very much, thats brilliant & very useful for the future. I'm a bit disappointed that there is no Bose fitted but it's not the end of the world. At least I know for sure now. Thanks again.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #26 on: 15 February 2012, 16:12:02 »
That's impressive Jimbob! Maybe send you mine next  ;D
twiglet
  • Norwich, Norfolk
« Reply #27 on: 15 February 2012, 20:39:58 »
Simples.  :y
O/S I believe James
Nope, N/S for the sub, O/S for the amp.  :y
