WTD headlight switch with front fog light button
Started by Omega_Dan, 15 February 2012, 23:15:21
Omega_Dan
Needed as im fitting front fogs and need the fog light button.
Dan :)
I may well have one Dan.Will confirm one way or the other in the morning. :y
Omega_Dan
twiglet
Just as a side note Dan, I'm guessing you will need one from a car without HID headlights, as you will need one with the thumb wheel to manually adjust the height of you headlights.  :y
Omega_Dan
Yes mate. Didn't realise there was more than 1 kind :)
twiglet
Yeah, the HID's are required by law to automatically adjust, therefore they have 2 level sensors that feed info to an ecu, and no manual thumb wheel.  :y
Omega_Dan
Quote from: twiglet on 16 February 2012, 08:10:47
The switch bank for front & rear fogs is a separate unit James. When removing from main switch the thumbwheel remains as it`s part of the switch body ;)
twiglet
Quote from: RobG on 16 February 2012, 08:30:37
How so Rob?
Do you mean you have to take the unit apart?
Anyone know how the light switch knob comes off ? The one I have here is the correct spec,but the knob has some wear and tear.Dan may be able to swap it over with his one.
Quote from: Albs on 16 February 2012, 08:42:24
Prise the fog switch bank out from underneath the main switch
twiglet
Rob, you're a legend!
So am I right in thinking that the main body of the unit is the same for all models (I've noticed they all have the same connections on the rear of the unit), and the fog switches and thumb wheels can be added to any of them?
Also, more for Dan's benefit really, I'm assuming the fog switch part can be removed without having to remove the whole switch unit from the dash?
Quote from: twiglet on 16 February 2012, 09:01:18
Main bodies are the same. If you don`t want to snap the retaining tang (2nd pic, middle of contacts) switch needs to be removed :)
Omega_Dan
Can the main light switch knob be swopped over?. Got your pm albs :y
