Author Topic: Inlet manifold bolt  (Read 2326 times)
chrisdb
  • Chesterfield
Inlet manifold bolt
« on: 16 February 2012, 14:45:31 »
Hi, the inlet manifold bolt - one of the corner ones securing the manifold to the engine block is not biting and will not tighten. It's been like this a while but all the other bolts are correctly torqued. Would this help account for my really high fuel comsumption and any ideas how I can fix it? The bolt itself is OK.
Cheers
Chris
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Inlet manifold bolt
« Reply #1 on: 16 February 2012, 14:57:48 »
helicoil to fix, dose the old bolt undo OK?  ???
chrisdb
  • Chesterfield
« Reply #2 on: 16 February 2012, 14:59:44 »
Great, thanks. Yes the old bot comes out OK.
« Reply #3 on: 16 February 2012, 15:51:47 »
Is it the inlet manifold to sandwich plate thats duff, if it is I would get a second hand sandwich plate just in case the brass insert has lifted a little which might cause an air leak ;)
chrisdb
  • Chesterfield
« Reply #4 on: 16 February 2012, 15:54:40 »
No, it's the aluminium manifold that sits on top. The bolt goes through the sandwich plate into the engine block.
« Reply #5 on: 16 February 2012, 17:07:08 »
Ok, some clarification needed.
Plenum
Inlet manifold
Plastic Inlet wedge
Block.
If the inlet manifold bolt is turning, it's the thread in the brass thread set in the plastic inlet wedge that is spinning round.
chrisdb
  • Chesterfield
« Reply #6 on: 16 February 2012, 17:15:58 »
Ah, its the Inlet manifold. That's much better than I hoped then, I did not realise it screwed into the plastic inlet wedge - that's much easier to fix then - I'll get another one.
Cheers!
chrisdb
  • Chesterfield
« Reply #7 on: 16 February 2012, 17:25:53 »
Scrap that, sorry. Just looked at the drawings in the EPC to remind myself as it's been a little while. It's the corner screw of the plastic inlet wedge which is spinning. So... back to the Helicoil?
Cheers
Chris
chrisdb
  • Chesterfield
« Reply #8 on: 29 February 2012, 15:43:01 »
2woody
  • Northumberland
« Reply #9 on: 29 February 2012, 15:56:51 »
you'll not get a helicoil in there - its a brass insert which is moulded into the nylon.
New inlet wedge required. Often called a "divider" on here
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #10 on: 29 February 2012, 16:04:44 »
Sorry I am unsure after reading which thread has stripped.
Is it one of the bolts the Divider/Sandwich Plate/ Inlet Plate to the heads or one of the six bolts that bolts the Inlet Manifold to the Inlet Plate?
If it one of the bolts that go into the heads, yes you can use a helicoil :y
2woody
  • Northumberland
« Reply #11 on: 29 February 2012, 16:15:49 »
yes of course
chrisdb
  • Chesterfield
« Reply #12 on: 29 February 2012, 16:44:18 »
Sorry, forgot to post the update ;D Got a set from Machine amrt - it was their own make of Helicoil, brand name Clarke - it was cheaper than the Heliocoil but worked brilliantly.
Cheers all :y
