Pages: 1 [2] 3  All   Go Down
Author Topic: Overheating !!  (Read 4060 times)
Re: Overheating !!
« Reply #15 on: 17 February 2012, 11:11:53 »
Re: Overheating !!
« Reply #16 on: 17 February 2012, 11:18:49 »
Thanks Albs  :y
The gauge does sit at 95 like in the guide but this quote :
If it climbs a tad above normal and is then brought back down by the fans cutting in then, again, that is normal.
Mine does climb above normal but i cant hear any fans cutting in  ::)
Re: Overheating !!
« Reply #17 on: 17 February 2012, 11:22:57 »
Sounds like you need to check out fuses etc for the fans.I vaguely remember when I had similar trouble,there was a fuse (10A iirc)in the engine bay  fuse/relay box for the fans.Its almost hidden by the big thick wiring loom which is in there.Might be worth a look. :y
Re: Overheating !!
« Reply #18 on: 17 February 2012, 11:27:06 »
Will check...
If i was to just keep the car running on tickover should the fans cut in eventually like they normally should say in traffic ...im thinking the switch is faulty if the fans dont cut in .
Re: Overheating !!
« Reply #19 on: 17 February 2012, 11:27:51 »
Big green 30A fuse
Re: Overheating !!
« Reply #20 on: 17 February 2012, 11:31:09 »
Nope.This was a small red one. :-\
Just check all of them. :D
Re: Overheating !!
« Reply #21 on: 17 February 2012, 11:33:58 »
 :D :D :D :D :D :D :D
All else fails i have a hammer  :-X   :y
Re: Overheating !!
« Reply #22 on: 17 February 2012, 11:38:30 »
That`s supposed to be without aircon :-\ #8a
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235/0
Re: Overheating !!
« Reply #23 on: 17 February 2012, 11:43:00 »
My aircon has been removed /bypassed with non aircon belt ...if that makes any difference   :-\
Re: Overheating !!
« Reply #24 on: 17 February 2012, 11:47:19 »
I think it would be 18A from that diagram. Bypassed aircon shouldnt make any difference afaik.
Re: Overheating !!
« Reply #25 on: 17 February 2012, 12:23:42 »
Fusebox in engine bay.
1 GREEN 30 AMP fuse blown
1 SUSPECT GREEN 30 amp blown next to it .
Is this been my problem  :-\
« Last Edit: 17 February 2012, 12:27:49 by eatmydust »
Re: Overheating !!
« Reply #26 on: 17 February 2012, 12:55:02 »
Probably.Replace them and see what happens.
P.S I said small red fuse,but it may actually have been green. :-[ ;D
Re: Overheating !!
« Reply #27 on: 17 February 2012, 13:11:43 »
Had some spares so i have replaced them , found a spare temp switch so that will be my next step if all else fails ..relays look ok but dont know how you tell if they are faulty other than looking for signs of being burnt out  :y
Re: Overheating !!
« Reply #28 on: 17 February 2012, 13:29:32 »
These 2 blown  :o
What do they control/fuse for  ???
Re: Overheating !!
« Reply #29 on: 17 February 2012, 13:47:57 »
::) :P
Pages: 1 [2] 3  All   Go Up
