Author Topic: poly bush question  (Read 1572 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
poly bush question
« on: 18 February 2012, 20:36:19 »
fitted my bushes over 6 months ago and ever since the handling has been terrible pulling side to side. it feels as if the bushes are too soft didnt know if they are diffrent hardness or are they all the same (they are purple) also did the wish bones and drop links at same time. also polyed roll bar too any help please :) :) :)
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
Re: poly bush question
« Reply #1 on: 18 February 2012, 20:43:59 »
The polys should have much less movement than the original rubber bush, who did your geo setup afterwards ?
plym ian
  • Plymouth, Devon
« Reply #2 on: 18 February 2012, 20:48:30 »
a local firm did it but it made no diffrence tbh
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 18 February 2012, 21:37:47 »
As Weds says, Poly should be stiffer than original rubber. How was the handling before? Have you checked camber/castor/tracking? Worth running string along to check toe. It does sound like castor or tracking to me. Are the tyres wearing OK?
plym ian
  • Plymouth, Devon
« Reply #4 on: 18 February 2012, 21:48:24 »
slight tramlining so might get tracking checked first
« Reply #5 on: 18 February 2012, 22:04:33 »
Did you have the CAMBER checked ??? ie .. FULL suspension alignement not just fancy tracking ??? Wishbones affect camber more than anything.
« Reply #6 on: 18 February 2012, 23:33:09 »
Are the wb bolts tightened correctly?
Has the car been set up correctly for full geo?
Are the tyres showing ware on the inside edge, from previous set up?
