Author Topic: Coolant leak  (Read 3119 times)
golly
Coolant leak
« on: 20 February 2012, 18:47:11 »
Hi all, my 03 2.6 Auto Est developed a leak,( standing at front of car ) it looks as though it is leaking from rear right bank, possibly running down where the gearbox meets the engine. This sounds like bad news to me, has anybody got ideas as to what the likely cause is ? Coolant leak not oil.
martin42
Re: Coolant leak
« Reply #1 on: 20 February 2012, 18:49:53 »
i would think its the hbv has given up
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Coolant leak
« Reply #2 on: 20 February 2012, 18:50:03 »
a good chance its the heater bypass valve, rear of drivers side head.
golly
Re: Coolant leak
« Reply #3 on: 20 February 2012, 19:03:43 »
ok, the heater is still working normaly, is this normal if the HBV was u/s ? Thanks for the advice.
Re: Coolant leak
« Reply #4 on: 20 February 2012, 19:08:07 »
Yep
http://www.omegaowners.com/forum/index.php?topic=90574.0
golly
Re: Coolant leak
« Reply #5 on: 20 February 2012, 19:20:04 »
Is this likely to be an expensive fix ? Thanks again folks.
Re: Coolant leak
« Reply #6 on: 20 February 2012, 19:22:06 »
Box of plasters and around £35 to buy from VX
Re: Coolant leak
« Reply #7 on: 20 February 2012, 19:22:59 »
Approx £40 from Vauxhall.Then depends if your capable of changing it yourself ? I believe theres a guide in the relevant section.Not  a technically difficult job,just a bit awkward. :y
Link to guide.
http://www.omegaowners.com/forum/index.php?topic=90573.0
« Last Edit: 20 February 2012, 19:27:43 by Albs »
golly
Re: Coolant leak
« Reply #8 on: 20 February 2012, 19:28:46 »
Thanks for all advice. I will give it a go, unless Daz is in the area.
Re: Coolant leak
« Reply #9 on: 20 February 2012, 19:29:28 »
Which area are you in Golly ?
Re: Coolant leak
« Reply #10 on: 20 February 2012, 19:30:16 »
Link to guide.
Wrong link :P. Mine`s the right one 8)
The Red Baron
Re: Coolant leak
« Reply #11 on: 20 February 2012, 19:32:10 »
dont forget the swear box Rob. lol
Re: Coolant leak
« Reply #12 on: 20 February 2012, 19:37:03 »
Just thought that was a foregone conclusion ;D
golly
Re: Coolant leak
« Reply #13 on: 20 February 2012, 19:48:49 »
TW14 0EG. Feltham nr Heathrow.
Re: Coolant leak
« Reply #14 on: 20 February 2012, 19:50:06 »
Link to guide.
Borrox.Presumably I clicked the one above or below. ::) :-[
